SOHC.co.uk Forums => CB500/550 => Topic started by: mickwinf on December 05, 2020, 04:33:26 PM
Just picked up a load of spares for 500/550 as a job lot, including an engine plus extra head etc and lots of other chassis and brake parts. I will be selling some of these to re-coup the cost so if anyone needs anything specific just ask.
hi oddjob its a 550 engine.
found some treasures in the pile, an undamaged fuse box cover which will go on my F2, and also a pair of headlamp brackets for F2 and K3 which seem in good condition except for a slight rust patch which may be a hole. Also a rear brake drum for the earlier 500/550 with the flat brake plate and the liner seems to be not cracked. Just having a look at the complete engine, it does seem to be seized up so investigating.
Long shot but have you got rubber spare fuse holder that goes in tool tray on 500 Mick?
Thanks Ken, I'll message Julie!
Phil, no sorry i have not seen one, Julie will sort you out. Oddjob i think i am keeping the engine for now at least, however i did get some other engine parts, a pair of crankcases with head and barrels and cam cover, not sure if its the pinned one or not i will check tomorrow. was it just the cam cover you need? oh just checked on pic and it is the pinned one
Just had reply from Julie and Trig hasn't had any made for a few years
more stuff
Hi Mick
Is there a rear mudguard and lamp from a 550 in there?
yes there is but has some damage at the end, mudguard is a k3 one i think with three holes. I have two lamp brackets, one k3 type which has a bit missing where the number plate mounts, the other is a chrome US type and in good condition
Hi oddjob, sorry to hear of your health issues, i will have a close look at the journals and the fork ears, although another member has first dibs.
Bad news ken, the journals are fine but on close inspection there is a chunk broken off at the edge, not sure if it could be welded. I have put a pic of the damage.
i have another one that is also cracked and in worse condition so can strip if you just need the internals, £25 inc post.
Mine is the same but a bit worse, but hey, no leaks and is just fine and dandy!
Hi Ken yes its the same but the journals are more worn, i will pm you
Hi Mick,
Do you happen to have a spare stator cover that is undamaged for a 550F?
Topcat
hi topcat, there is one in the pile, i will have a close look and let you know what condition it is in
Perfect thanks Mick, Other things I'd be interested in if you have any or are willing to sell. An oil pump assembly for the 550F and the neutral switch mechanism (just the sheet metal part that makes contact with the rotor wheel. Also if you have the left crank case cover that'd also be good, I have one but its pretty beaten up.
Let me know
Topcat
I have some nos neutral switches if you are interested pm me for price
hey Topcat, i had a look at the alternator cover but it has some damage, no oil pump, i think somewhere i have a neutral switch but seem to remember it was a bit bent so Bryans new one might be better. I have a left cover which is good, no deep scratches, will need polishing.
Ken, money received and i have removed them from the cover, will get them off in the next day or two.
more stuff
Is the hub 500 or 550 F2 / K3 ? Will take the tool tray mesh please Mick. And chain stopper please
Hi Julie, the hub is the earlier type with the flat brake plate, it has no bearings in but i have most of the bits if you need them. did you need both chain stoppers?
regards, Mick
regards, Mick
So the hub is 500 four (323) ? Is the brake liner cracked or badly worn ?
Yes please Mick, the two stoppers and the tool box mesh holder. :-*
Hi
Would you have the lower yoke stem for a CB550 in the boxes of spare please as some muppet before has stripped the upper thread on mine, so need a new/second hand one
Rgds
Nigel
Hi Nigel sorry no bottom yoke
Julie here are some more pics of the hub, the liner looks good to me, a bit of surface marking but cant see any cracks, let me know if you need all the other hub bits ie brakeplate etc and PM me with a fair offer :)
PM sent Mick.
a few items sold here are some more pics, k3 brake lever, starter cover and battery box.
has everyone received their parcels?
Have not had any xmas pressies from you ;)
ha you have to fetch from Santa ;D
Yes arrived today at hanks Si
in amongst the 550 stuff was these handlebar switches, they look like they could be 250 k or smaller bikes with drum brakes? anyone recognize them?
