SOHC.co.uk Forums => CB650 => Topic started by: beermaker on May 29, 2010, 01:51:24 PM
Thought I'd better move this to here rather than continue on the introductions page :o)
Quick summary - managed to strip off the rocker covers, breather and the cylinder head cover, and cleaned the rocker covers up with a wire wheel and a buffer. Sold my little honda H100S so got a bit more room now until I pick up my ZXR400, and my partners just took the kids over to their dads for a bit so I'm going to take advantage of the time and see if I can get the whole engine out of the frame before they get back! Will take the camera in and see if I can get some reasonable pics to post up :o)
Philip
Take lots of photos as you strip it, it helps when you start putting it back ! Cable, wiring runs, breathers etc, all the things that you forget easily.
Den
got to confess I've not done much to it lately :( sheared a cylinder head bolt and got fed up! Going to have a go at taking the engine out as a lump and stripping it on the bench, although got to clear some shed space first. Shed's being used as a dumping ground whilst we sort the house so I can barely get in let alone fettle the bike! Grr!!!
Hope to be able to report some progress soon!
Phil..so how is progress on this? Stick with it & post some piccies!
All the best projects take ages!
