SOHC.co.uk Forums => CB650 => Topic started by: kemp2368 on June 26, 2010, 01:20:17 PM
Title: strange starting problem
Post by: kemp2368 on June 26, 2010, 01:20:17 PM
hi all,since i am still learning about this bike :-[ i get a strange problem now and again when i start her up
it is that when i press starter button she just turns over without engine firing, neutral light is on,almost like electrical fault
i then shift through the gears and then back to get neutral light back and she then is fine
i have read tha haynes ,and noticed there is a clutch fail safe
anynone got any ideas :)
Title: Re: strange starting problem
Post by: pae on June 26, 2010, 09:38:26 PM
Could be the infamous starter clutch, they are prone to fail. Do you hear anything, like a whirring or fast clicking, when it fails to spin the engine?
If I remember, the clutch failsafe means that the clutch needs to be pulled in the bike is in gear. There's a neutral interlock that stops you from turning the engine over with it in gear, and this can be over-ridden by pulling the clutch lever in. The neutral connection is behind the front sprocket cover, the clutch interlock is on the clutch lever.
Post by: kemp2368 on June 26, 2010, 09:52:23 PM
hi there,thanks for the reply :)
there is no clicking or whirring,the engine still turns over as normal,also if i try to start it in gear the same thing happens if i pull the clutch in(engine turns over fine but does not fire)then i shift  through the gears then try it when neutral   light is back on and all is fine,i might try and have a look at the neutral connection when i get a mo
Graham
Post by: notobikeparkingtax on June 27, 2010, 01:18:05 AM
Do you normally leave the bike with the fuel tap turned off? Try leaving it in the ON or PRIME position and see if it starts easier.
Sounds to me like slight fuel starvation. Running up and down the gearbox will have no effect on starting, it will however give the float bowls a little extra time to fill up.
What happens if instead of going up and down the gears you just let it sit for a few seconds ?
Post by: Spitfire on June 27, 2010, 08:12:20 AM
Sounds really strange this one, so the starter turns over but the engine does not fire as if the kill switch is in the off position, and a quick cycle through the gears resets it. Most peculier !
Den
Post by: kemp2368 on June 27, 2010, 08:28:22 AM
hi there,it makes no diff if i leave fuel tap on or off,it only happens twice a week if i use it every day
Post by: kemp2368 on June 27, 2010, 08:31:48 AM
Den
yes you have nailed the symptoms on the head,it is  like the kill switch being on,as it is at the moment i can put up with it,but its just a bit strange
i don't have a kill switch button at the mo as the button was not there when i got the bike
Post by: pae on June 27, 2010, 03:59:51 PM
I wonder whether the neutral interlock is playing up, and running it up and down the gears shakes it back into life. Although you say the neutral light shows on when it's happening so possibly not, but maybe the light is OK but the interlock circuit isn't always breaking (or making, not sure which it does)...
Let me have a look at the manual and think about it.
When it next happens, put it into first gear, pull the clutch in, and see if it starts then.
Post by: kemp2368 on June 28, 2010, 07:04:33 PM
ok it happened when i  started it to come home from work ??? so when the neutral light still on i pulled the clutch in and she started 1st time :)
so does this mean the neutral interlock is playing up??
Post by: pae on June 28, 2010, 08:52:26 PM
Could be, as pulling the clutch in should over-ride the "not in neutral" signal from the gear selector. So although your neutral light is on it seems that maybe the interlock thinks it ain't in neutral.
I still need to check the manual though as I'd have thought it's the same circuit and therefore both signals (whether right or wrong) should match.
Post by: kemp2368 on July 01, 2010, 08:37:42 PM
hi all,at last i have found the problem
as i said before i have not had the bike for long and started to explore when the problem happened again,i traced a few wires from clutch lever etc and found that every time i turned the handle bars to the left all the lights etc went off,when i straighten them it would all work fine :(
so loose wire somewhere ???
i found it :) :)
it was the earth to the coils underneath the tank,someone has had a right go at this as found 5 green earth cables had been soldered(not very well) see pic
Post by: pae on July 01, 2010, 09:56:24 PM
Oh, that's a nice spot of re-wiring you've inherited! Still, all valuable experience, you'll know the bike inside-out soon... glad you got sorted though,
