SOHC.co.uk Forums => CB750 => Topic started by: Moxey on August 09, 2018, 09:54:40 AM
Morning
A little while ago I bought some stainless mount bolts for my 750f2 (one of mine was a little bent and the threads were a bit suspect, also I am a bit of a tart ;D).
The kit I purchased was from Zedparts, of the 3 mounting bolts 2 were fine but the rear lower engine mount (12mm) which goes through the footpegs is considerably shorter (50mm or so).
(https://i.imgur.com/ixhWtkh.jpg)
Now I've mentioned this to the seller on the presumption they sent the wrong bolt and they say they have never cut a bolt this long for a 750 SOHC K or F so I'm wondering is this the original bolt?
From memory the F2 has a longer bolt as it goes through the two alloy footrest plates, try comparing part numbers on CMSNL
