SOHC.co.uk Forums => CB350/400 => Topic started by: beemsquar on June 30, 2015, 02:48:46 PM
Hello all
I am a newbie to the forum and am just after a bit of advice, this is my first ever proper bike, ( I had a DT50 when I was a young) but I have restored a few classic cars in the past and have always worked on my own vehicles, so I have some mechanical knowledge.
I'm just about to pick up my first honda CB400 super sport 1976 f1 as a restoration project or possible brat tracker project, I haven't decided yet!
The bike is running, but has a lots of parts in boxes so isn't road worthy yet.
I m thinking modify it, as I'm looking for a winter project and have seen some very inspirational 550 cafe racer/brat trackers, but I guess this will be worth more in original spec?
My main questions are mechanical for a first time bike project ...
Are the bolts etc imperial or metric on this year?
Could you recommend an average priced / good quality socket set?
Are there any speciality tools I might need with this honda?
I have a reasonable selection of mechanics tools at the moment, but i'm looking to expand my range. I would also like to know if there are any bike specific tools you guys found have made your lives a lot easier?
I am borrowing a motorcycle bench from my dad, as he has restored a few triumphs in the past.
I am also looking at a cheap parts washer and possibly a soda blaster as I'm planning on doing as much work myself.
I was thinking of doing a complete engine rebuild, but what do you guys think? its currently got 46000 on the clock.
Again I've never taken a bike apart, but I did completely rebuild a Triumph spitfire from the chassis up to a very high standard.
Any advice would be greatly appreciated!
Andy
Welcome to the forum from a fellow 400four owner.
Go for the single hex 3/8 sockets; they are less likely to round the bolt heads.
Pt 2 Phillips screwdriver (with the tip ground off) fits the crankcase screws.
Pt 1 Phillips screwdriver
Impact driver for the hard-to-shift screws.
22mm ring spanner/ socket for the rear wheel.
No doubt you'll add to your toolbox as the need arises.
Mike
Cheers guys!
Good advice on the single hex mike, i have never heard of them before but a quick google search shows they are much better for removing rusty bolts.
I have a snap on 3/4 and a mediocre 3/8 set and a good 3/8 torque wrench too, but was going to buy a new 3/8 set tomorrow as I don't want to be rounding off bolt heads and damaging a nice new painted frame!
What do you guys think of this set?
http://www.amazon.co.uk/Britool-E031806B-8-inch-Socket-Pieces/dp/B004ZDVF2A
Yeah I would like to strip the motor just to be sure, plus that's part of the fun! Would you upgrade anything while you're in there?
I know I will need a new gasket set and cam chain, what about upgrading the carbs?
Are there any online tutorials or books you would recommend for stripping the engine?
I have a haynes for it and was going to buy a Clymer manual too.
Can you recommend any online specialists to get engine parts from and what would you replace as a minimum?
Thanks again for all your help!!!!
Your easiest option for parts is David Silver Spares. Very good online service or phone, not the cheapest but very reliable. Or there's CMS in Holland, and a fair number in Germany plus good old fleabay. Good luck with the build, If you get stuck just ask. Cheers Roy.
I'd strip the carbs completely and dunk all of the jets, emulsion tubes into an ultrasonic cleaner One of those little jewellery cleaners will do but bigger is better.
As for the socket set, you don't need the whole kit. You could buy just the sockets you need;
8, 10, 12, 14, 17, 19, 22.
Better than single hex are wall drive sockets. These grip the walls of the nut or bolt rather than the corners. Like this one...
http://www.ebay.co.uk/itm/Sealey-WallDrive-Socket-17mm-3-8-Square-Drive-Individual-Impact-Socket-S3817-/191412487348?pt=LH_DefaultDomain_3&hash=item2c9112c4b4 (http://www.ebay.co.uk/itm/Sealey-WallDrive-Socket-17mm-3-8-Square-Drive-Individual-Impact-Socket-S3817-/191412487348?pt=LH_DefaultDomain_3&hash=item2c9112c4b4)
Welcome to the forum Andy !
I'm a few months ahead of you with a similar project and from a similar background ! As others have mentioned, you'll probably find that you have most of the tools required if you have restored cars, but from my experience, I'd say an impact driver and a tap & die set were very useful ! (had to clean out every tapped hole in crankcases after blast cleaning !) and you'll probably want the specialist tools for clutch removal
Parts seem pretty easily available from David Silver etc and the CMSL web site has invaluable diagrams on every part of the bike. The advice and knowledge here is a priceless commodity and I'll happily answer any Qu's you have if I can - I'm by no means an expert, but there's a good chance that I will have recently done whatever you're about to do !
Enjoy the rebuild and the advice / experience on here, and look forward to getting the bike back on the road (I'm not far off now !)
Andy
Hi Andy, watch out for the bolts on a Honda, some are metric fine and some have different sized heads to standard, here is a write up that I got from the Custom Fasteners site when I was ordering bolts for my rebuild.
http://custom-fasteners.co.uk/
IMPORTANT - PLEASE READ BEFORE ORDERING METRIC BOLTS.
Metric bolts in M4, M5, M6, M7 and M8 diameters are suitable for both European and Japanese motorcycles and cars.
However, M10 in the standard 1.50 pitch are only suitable as replacements on European machines. They will not fit Japanese vehicles which use their own specialised fine thread. Please see the next section in the catalogue for our specially produced range of M10 and M12 fine thread bolts for Japanese vehicles.
M10(1.25 pitch) and M12(1.25 pitch) FINE THREAD METRIC BOLTS
For use on Japanese motorcycles and cars. M10(1.25) bolts have a 17mm spanner size, M12(1.25) bolts have a l9mm spanner size. The Japanese often
use a smaller size head on their bolts, so please check there is sufficient clearance for the standard size head we supply, before ordering.
NOTES ON METRIC BOLTS
M4 fits spanner size 7mm. M4 thread pitch is 0.70mm.
M5 fits spanner size 8mm. M5 thread pitch is 0.80mm.
M6 fits spanner size 10mm. M6 thread pitch is 1.00mm.
M7 fits spanner size 11mm. M7 thread pitch is 1.00mm.
M8 fits spanner size 13mm. (Japanese M8 bolts use 12mm spanner size). M8 thread pitch is 1.25mm.
M10 fits spanner size 17mm. M10 thread pitch is 1.50mm.
[/i]
Hi Andy, Welcome from me to.
If you need to overhaul your carbs then I and a number of others have used the rebuild kits from Cruzinimage.
http://stores.ebay.co.uk/cruzinimage-uk1484
They do other parts as well, have a browse through their shop. I recently noticed a master cylinder rebuild kit a lot cheaper than the one I had bought from DS.
Welcome.
Have fun with your 400/4 and the forum
Julie
Forgot to add that you will probably find a Parts List very useful, both for part numbers and to show
where bits go. I got mine from here which seems good value at £12:
http://www.ebay.co.uk/itm/Honda-Parts-List-Book-CB400F-400-4-400-Four-1970s-Reproduction-Original-Honda-/251407786645?pt=LH_DefaultDomain_3&hash=item3a89126295
Welcome from me too. I have an 8/75 CB400F myself. Lovely little bikes and much easier to restore now repro parts available.
You can download a Genuine Honda Service (Shop) manual off my Dropbox here for free: Plus parts list.
https://www.dropbox.com/s/zh31qynxfimw8pb/400_4%20Shop%20Manual.pdf?dl=0
https://www.dropbox.com/s/u51uf0p1dv6m29q/Honda%20CB400%20F%20Parts%20Manual.pdf?dl=0
What I find as a non-pro is that if the cross head screws are chewed up a bit, reform the cross as best as you can with hammer and flat head punch. Then whack the punch against the head with a hammer to jar the threads and then use a decent fitting crossherad driver to remove. If you hit the head of the driver with a hammer it will reform the crosshead in the screw. If totally knadgered , either use a cold chisel on the side of the screw head to try to tap round or drill out. ALL with great care and attention of course. Impact driver useful of course if you have one but take care not to hit it too hard and not much use if the screw head is f'ed.
Ash
All fantastic advice, thank you all so much!!!!
This is the sort of advice I was hoping for, people who have had first hand experience on these machines who are willing to share their knowledge.
I will download the manuals now and have look over the next couple of days, Socket set is ordered and I have just built myself a nice new workbench in the garage, as the old one wasn't very stable.
I dont actually have the bike in my possession until Sunday, so just trying to prep my work area as best I can before then.
Looks like there's a few other tools I will need along the way, but I will get them as needed. Although I am in the market for a compressor as my old one went kaput last week! What size unit would you recommend? I had a 25l, but it was forever refilling when using a nail gun, I was looking at a 50l V-twin Wolf cheyenne?
Thank you for all the links, good to know some part supplies that others have used in the past too.
Andy
I find these to be most helpful, also a decent multimeter.
[attachimg=1][attachimg=2]
Welcome to the mad world of the SOHC, loads of great advise to be had. I use Metrinch sockets as they will take off any rounded nut or bolt. Britool are a good tool but, the old stuff is a lot more stronger and better made.
Just finished a 40+hour week in 3 1/2 days so been a bit tired, for want of a better word.
I concurr with most of the above, not sure but i think britool was bought out by facom.
Personaly i would buy a relatively cheap set of sockets and replace the ones that show signs of wear with quality ones, i still have some from a £3 set ( of 12 sockets) that are unused so it would have been crazy to buy quality for those.
Long, 6 sided sockets are a godsend for things like head nuts and always get 3/8 drive, or maybe even 1/4 drive as they have thinner walls for things like the sump bolts. Also 3/8 drive torque wrench as the 1/2 inch ones tend to not go down low enough
There are two engine special tools needed
(1) castellated clutch nut remover replacer availabale on ebay
(2) rotor puller--for the number of times you would need this probably cheaper to take the crank to a Honda dealer and let them use the special tool---you can get it from dave Silver but its about £35 from memory(and fits all Honda fours )
Chassis wise there are the wheel bearing retainer tools that show on Ebay, but again for one off somebody on here might have one or your local dealer
Cheers guys. I bought a 45 piece 6 sided wall drive Sealey ratchet set in the end for £60 in the end as heard the same as you Bryanj, that the quality wasn't quite the same. plus this will do me fine for the amount of time I will be using it and give me some more pennies to spend on bike parts!
Bodd, is that a stud extractor set in the picture on the right?
Also, just looked at your 400 cafe build, fantastic job, looks awesome! This has helped me in working out a sensible order for taking my 400 apart! How long did this take you to do and what sort of price did it cost in parts, if you don't mind me asking? I also like you, intend to do as much of this project myself as I possibly can. I have never liked paying someone to do something for me, plus I like the challenge and want to learn.
My bikes side stand is also too short and its missing the paddock stand, wonder if mine has been fitted with the wrong one now!
Where did you get the mag base and clock you used for balancing your wheels?
Andy
The box with the blue lining contains rounded nut and bolt removers, they go over the rounded nut or bolt head and when you get a spanner or socket on them the twisted inside bites into the nut or bolt head, the other box is for those occasions when the bolt head comes off when there isn't enough sticking out to get a stud extractor on.
The cafe bike took just over 2 years to do but in that time I had to take a couple of sabbaticals where I didn't touch it for a couple of months at a time, total cost including buying the bike was just over £1500, the only stuff I paid someone else to do was to paint the tank & seat and a few bits of chroming, I've also got quite a few parts to sell on so the cost will come down a bit more.
Cheers Bodd,
you've done a fantastic job. very meticulous and done spending such little money! I've taken some good points from your blog on parts to order without getting ripped off!
what was the mag base and clock you used to balance your wheels? re-spoking and balancing is something I would like to do myself too.
Andy
It was a plunger clock I use for the timing of the RD250E, I only wanted the clock to use with an old plug to make a timing gauge (see pics below) but the guy I bought it off at an auto jumble wouldn't sell it without the mag base. Doing the wheels isn't as hard as the professionals would have you think, they make it out to be a bit of a black art and charge quite a lot to do it but it isn't that hard, it's no more difficult than tuning my drums.
Hi if you fit new bolts be aware the bottom left hand engine to frame bolt is critical length if you leave the washer of or remove crash bars it can puncture the engine case into a oil gallery.
Been there, done that. There's only 2mm difference in the bolt length, they look identical unless you know what you're looking for.
That's one of the things where I found the Parts List useful, it has the bolt sizes in.
Agreed, unlike the Suzuki parts list.
If its a normal bolt the Suzuki part number contains diameter and length.
Whereabouts in Dorset are you ?. I live in Poole and have a couple of 400/4, I have a number of the special tools needed for pulling the engine apart i.e clutch hub nut rotor puller. If you get stuck let me know.
Paul
Thanks for the heads up on the bolt length! I dont want to make that mistake!
Cheers Paul! I also live in Poole! if you have any spare parts for sale I'm looking for a few bits.... actually a lot! I picked the bike up on Friday and it was worse than I had thought, but I knocked the guy down and took it anyway. Hope I dont regret it. It came with boxes with parts in so who knows what i'm missing.
So far I've labeled, sorted and stripped most of the parts off the frame, just got the engine to remove and the front forks. I've kept the wheels on for now as the side kickstand has been badly repaired and is at the wrong angle, so the bike leans over to far. I'm trying to find out the correct angle and side stand length before I go any further. Its also missing the centre stand.
Hi Andy, welcome & enjoy your rebuild. It's an easy bike to source parts for; many options.
David Silver Spares (as you know) has a lot of 'new' parts - at a cost, but second hand bits can often be found here...
http://www.400fourbits.co.uk/
Sometimes Steve's description can be a little, um, optimistic, but he offers good service and often has those hard-to-find bits.
Simon
Cheers Simon, a thorough site if not a little complicated to order. thank you.
Yea, rather annoying in that you've first gotta contact Steve for a price. But with Internet banking you soon have an account # to transfer to, and after the first transaction it all becomes slick.
Where this site comes into it's own is those 'one off parts' that just bloody evade you everywhere else; you can get lucky.
Simon
