SOHC.co.uk Forums => CB350/400 => Topic started by: billdn on November 12, 2021, 02:45:03 PM
I suspected a damaged wire and slit this covering open, but thankfully no damage, but how to replace/make good - I suspect it gets hot hence the woven type sleeve so 2 questions :-
a) cover with heat shrink - don't think its suitable tbh.
b) Vehicle wiring products do similar on their site , use that?
c) insulation tape- only kidding!
I know don't do that again but was only looking honest, the field core wires covering is also bit frayed so possibly change that also.
I seem to recall its called systoflex, probably wrong spelling
Right spelling Bryan, but doesn't appear to be made , I'll try Vehicle Wiring Products woven sleeving looks similar.
what about the heat proof tape they use when powder coating, that's a secure wrap and is heat resistant?
Just a thought and a bit of a guess but it seems to be good stuff and used in numerous applications........
Well last time i used it was in 75 on a 3ph turbo alternator just off Saigon
RS PRO Braided Acrylic Fibreglass Black Cable Sleeve, 2mm Diameter, 5m Length
Spotted that one Bryan, anyone need spare 4m 🤣
Sounds like a urine infection :D
I need a couple of metres.
Is the stuff on AES any good for this?
https://www.autoelectricsupplies.co.uk/product/342/category/66
Cheers,
Andy
If you need any white I've used this in the past.
https://www.ebay.co.uk/itm/401348381710?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
What size did you use Deano?
Hi Phil.
Can't remember what I bought but measuring what I have in the garage it appears to be 6mm and 8mm dia. I used it on a 400/4, the 6mm for the two wires from the points and the 8mm for the 3 wires on the alternator side. I used a bit of tape on the ends to secure the the sleeving and than covered the tape with black heat shrink to finish it off.
Valuable tip, bookmarked... 8)
