SOHC.co.uk Forums => CB750 => Topic started by: Brett72 on November 28, 2020, 10:05:11 PM
Title: Struggling splitting engine case
Post by: Brett72 on November 28, 2020, 10:05:11 PM
Evening all. i am after some advice if possible from the font of knowledge on here.  I am struggling to separate my engine cases. I have followed the good ole Haynes manual to the letter but i just cannot seem to separate them. Have tried lots of different size persuasion tools but they just wont budge. Is there a bolt that the book doesn't show? Do you need to remove the alternator off the shaft? i have seen many videos where they don't. Is there a bolt under the sump plate near the oil pump? Any ideas are welcome. Thanks
Title: Re: Struggling splitting engine case
Post by: Trigger on November 28, 2020, 10:27:28 PM
You need all covers off and the oil pump removed. Are you missing the bolt under the starter motor cover ? Once all bolts are out and the engine up side down, give the output shaft a tap with a plastic hammer  ;)
Post by: Brett72 on November 28, 2020, 10:28:56 PM
Thanks Trigger i will give it a go tomorrow
