SOHC.co.uk Forums => CB750 => Topic started by: johnm37 on April 10, 2023, 06:49:57 PM
Hi to everyone. I'm a new member having only just dicovered this forum. I don't like starting by asking for help but I've a problem.
I got my bike out for it's first ride of the year. It rode for a few yards and stopped. A piece of rag had tangled between the chain and front sproket. Then I made my big mistake. I slackened off the chain and tried to force the rag round the sprocket. I now have a big hole in my gearbox. The damage only seems to be to the bottom part of the casing.
It looks like it's engine out to repair this.
Can I split the gearbox bottom without a complete engine strip?
My repair options seem to be: rebuild the area with epoxy putty. Stick the broken bits back in with epoxy or get the casing welded. That is my favourite. I could get the casing built up with weld or weld the broken bits back in.
What do you guys think?
I'm a capable mechanic type but with little experience on bikes.
The rest of the bike is ok. I don't want to sell it and like the idea of keeping as many original parts as possible.
Thanks in advance
John
Welcome to the forum John,
Yes you can split the motor without stripping the top end.
You could try a botch up with JB weld or something, nothing to loose.
The proper way is a weld repair which has already been documented some where on this forum.
Good luck
Skoti
What you could do ismeticulously clen and epoxy the bits in so you can use then have it welded when the engine needs work.
Depending on mileage it could be due exhaust valve guides anyway, they only lasted 15 to 30,000 anyway
Feel your pain. Are you certain nothing has gone inside the case?
I'm fairly sure I've got all the bits out. I've looked at an epoxy repair. It's a possibilty but supporting the broken parts while the epoxy sets isn't easy and there's not much clearance between the case and gears.
I'm thinking it's engine out and weld the bits back together. That way I can check the internals at the same time.
I might also look at other things while it's out. I wasn't aware of the valve guide issue. I may check those at the same time.
How do I split the crankcase without removing pistons etc? Getting at the main bearing bolts seems an issue. It sounds like I can check the crank bearings too.
The bike has only done 15,000 fairly careful miles so I'm hoping it won't need much work.
John
All te side cases come off then you unbolt all the case half bolts and remove the lower case
Welcome to the forum John.
What a shame to get caught out with that. Ultimately it needs to be welded I agree with you on that, wouldn't stick the broken bits back in with it in situ. If you want to delay the work then you could make a thin patch in aluminium to cover the hole and epoxy that to the surrounding surface as temporary cover.
To remove the bottom case as noted, I'd also thoroughly clean them all outside firstly to avoid any extraneous grit etc from finding it's way inside as you're not going to strip it out completely.
I like the F2 model and hope you can get it fixed, its not too bad a job to remove that case (motor upside-down) but probably more of a task getting out of the frame as they're fairly close fitted all round.
Plenty of advice on here to help with anything you need to ask.
If you dont have a parts book to see which parts split worth checking https://www.cmsnl.com/honda-cb750f2-super-sport-england_model14689/partslist/ (https://www.cmsnl.com/honda-cb750f2-super-sport-england_model14689/partslist/)
Well I've finally got the engine out and split. The bad news is there's the hole in the lower casting but the top casting us also cracked in 2 places.
I took the 2 parts along with the broken bits to my welder. He tried to weld it with a variety of rods but they spat everywhere and wouldn't make a run. He was using a TIG welder and is experienced. Does anyone know what sort of rods and gas work for this? Failing that, any recommendations for someone who can weld it? I'm near Abingdon in Oxfordshire.
My final option seems to be a second hand pair of casings. I've found a new pair for sale but at £2700+ they're eye wateringly expensive.
Thanks for the tip about cmsnl. I've downloaded all of their drawings.
Spitting like that is usually contamination, are you sure they were really clean and the black paint removed. They also need to be preheated and welded a bit at a time to avoid distortion. Give DK in Stafford a ring, they may have some good used cases for sale or try good old eBay.
Sent from my Pixel 7 Pro using Tapatalk
Try this, bit pricey but may fix your problem.
https://www.cb-four.com/cgi-bin/shop/__Engine-Block-Honda-CB750Four-F2-G-used-__21-3297-10_07.07.html (https://www.cb-four.com/cgi-bin/shop/__Engine-Block-Honda-CB750Four-F2-G-used-__21-3297-10_07.07.html)
Might take some time finding one but a good used case looks like the best way forward.
Cheaper than the ones found already and would suit if correct
I’ve dealt with Zcb-four on numerous times and are super efficient as you’d expect and really good to deal with. Highly recommended.
The engine number on these cases looks a bit fishy but it is actually a UK only 750F2. So it is the correct part. Strange how a UK bike has ended up on a German website.
My welder did clean off all the paint and also pre-heated it. He only tried on a broken piece but he doesn't think it's weldable.
Yes, DK are good. I've bought from them before. It's quite a distance but could be worth it. They have at least one pair of casings listed. I suspect they will be seeing me soon.
DK do a reasonably priced delivery service with a fair returns policy - worth speaking to them I would have thought as you have dealt with them before.
What’s the engine number on the cases you’re trying to replace?
Engine No. B750GE-1004112
I've had some good luck on this, I hope. Since TIG welding doesn't work, I decided to try some of these wonder rods that weld aluminium at low temperature. My local stockist (who I tend to trust to sell quality stuff) sells Durafix. Not cheap but worth a try. So far all I've done is tin the part that's broken off. The rods worked really well even at my first attempt. Having put a pool of Durafix on the metal, I ground it back with a power file. It's harder than the aluminium and certainly adhered well. Tomorrow I will try welding the pieces back together and let you know how it goes. Fingers crossed.
There's various video's of Durafix on Youtube.
Also, I have no connection with the company.
John
That sounds interesting. Take some pictures along the way so we can see the process. Best of luck with it. The cases for sale at cb-four are in the correct number range for your engine should the weld not turn out well.
John, I also would be interested to see how the Durafix rods work. I have some ally to try and repair and was thinking of this approach. It may also work to replace a fin on a cylinder barrel I have (maybe)
My thinking also, intrigued to see not only the process but the results you end up with. I’ve had a quick look on the net but the difficulties of your repair really would highlight it’s usefulness and versatility if it proves to be a winner for you.
The issue I had with it is getting enough heat into the material you are repairing.
Did some fin repairs on CB350 and found that it required a tremendous ammount of heat,and of course the instant you go above your left with a blob!
Took an assistant with oxcy/acet keeping head hot and holding repair peice in position while I held,another torch and filler rod.
Will never attempt again.
You're right about the amount of heat needed. Aluminium conducts it away too well. I started with a blow lamp but that took ages. Oxy acetylene worked better. The biggest problem was not hitting the rod with the flame. Do that and it turns to paste and won't flow.
I managed a reasonable repair. It's certainly strong. I hope I've sealed all the cracks to stop oil leaks. I welded the big piece back in. Then I put a piece of stainless steel behind the hole to support the weld puddle. That worked well. The Durafix didn't stick to the stainless allowing me to fill quite a large hole.
I've taken pictures but they're over the 3Mb limit for posting. I will try again tomorrow.
Tomorrow it's the turn of the top casting.
Be careful you don't get too much in there as the gears behind the repair are very close to the casing.
For risk of leaking, many casting when they were more porous are painted internally to prevent this.
A decent coat of something oil resistant may be worthwhile here.
Well the top casing was much more difficult to weld. Durafix doest like vertical use. It just runs off into a large puddle. Its I also almost impossible to weld both sides of the casing. Heating up for the second weld just melts off the filler from the first. I went through a couple of rods before giving up.
My next attempt was better. I lifted the engine so the area to be welded was nearly horizontal. That gave a reasonable weld. Certainly strong enough for such a small area on the casing.
Having welded the inside of both cracks, I am going to reinforce the outside with epoxy putty. I use evostick putty. It's 2 parts of putty which you break off and nead together. I've used it before and it sets very hard. It can be sanded, filed, drilled and tapped. It also sticks to almost anything including hands so use gloves when handling it.
There's more room to use this on the outside. This should be the last step in the repair of the casings.
I would attach pictures but they're above the 3Mb limit on this forum.
I coated the inside repairs with Evo-Stik epoxy metal. It's more liquid than the putty stuff so can be spread on easily. The idea is to cover any remaining cracks to prevent oil leaks.
I will still reinforce the outside with epoxy putty.
Great work there John
John, that is good work. Based on that, I'm going to have a go with Durafix on one of my fins that has broken off. I think I'll use a copper (or s/steel) wedge between the fins and just weld from one side and see how it goes.
I have lost count on how many cases i have welded up with holes and some the size of my fist.
It is no good using any type of epoxy fillers as, they always fail in the end. To do this repair correctly the case needs to be bolted down to a inch and a half block of steel to stop any heat distortion from the alloy welding and then welded up a little at a time until it is fully built up, then it is a lot of grinding, milling the matting surface and clean then paint.
You will need to have enough clearance from the final drive cog as, this sits very close to the rear of the cases.
