SOHC.co.uk Forums => CB350/400 => Topic started by: Lynx on August 29, 2013, 03:40:29 PM
Hi guys,
Today's question is when using a strobe light, what revs and timing marks should I use.
Regards
Steve
From a 400F maintenance manual.
Hope it helps,
Simon
A strobe IS ONLY USED for checking the advance mechanism NOT for setting the timing
STROBE is good for checking the advance and for "FIRE TIME" adjust, you can do both, "Timming and Advance".
Best Regards.
Thanks for the instructions.
I always though setting with a strobe was MORE accurate than setting static as it is more real world, setting on a running engine. You can see when the spark plug actually gets the signal.
Yes, I just upload one PDF about it, look my last post!!!
Sorry for my English.
Hi Piki,
Where is the PDF?
Is a Post called HONDA FOUR SERVICE in MISC/OPEN.
Bryan,
If like me you in previous years attended a Honda course was your course different to mine.The Honda training guys showed us on the course that using a strobe light was the best way of doing it For all Honda bikes so I don't know where you get your ideas from can you explain more for me as I am trying to remember all I was taught?I know about the dwell etc but for years have I practiced something the manufacture taught me and now is wrong.
Bitsa
I did the training in the 70's and was told to set the gap with feelers, the timing static with a bulb and then check the advancer with a strobe BUT you had to be good with feelers to get the gap right (and have a set with a 14thou one!) have patience and practice to get gap and timing right at the same time and to be honest unless a problem was reported by the customer rarely bothered to use a strobe as it took too long to set up the Honda box!--likewise the dwell box
i always found that the advancer started opening very early so using a strobe set the timing advanced but still in the marks on full advance.
You have to remember I was apprenticed in 69 and brought up on old Fords to the extent that i proved to an apprentice in the 80's who tried to tell me it was impossible to set points and timing without a dwell box and a strobe that i could do an essex v6 (capri 3.0) in half the time it took him and get better results.
A dwell box and strobe may well be easier for someone who does not do the job often but seems like witchcraft to this old timer mate
I have the "Honda Box" and 10 Minute is enought for a Perfect Tune-up.
I used to find that my CB750 K1 was a bugger to time up.
The only way I could get the ignition timing spot on was to set different points gap !
I even bought several point sets but to no avail, they always had to be set different.
I found out later that the gap is not as important as the dwell and if you did not get the timing right the pipes would go blue very quick.
I have a dwell meter and a strobe with a power source and after setting/checking the gap I alter it to get the correct dwell then adjust the timing regardless of the gap. If the dwell is correct you will always get a fatter spark.
Dwell more important than gap! But if you fit Boyer electronic you would think you were riding a more powerful bike.
