SOHC.co.uk Forums => CB350/400 => Topic started by: stevush on September 22, 2015, 05:52:17 PM
Hi Chaps,
I've just bought a used engine today and taken the barrels to S.E.P in Kegworth for assessment. The verdict ?
I need a rebore "See what you pistons and rings you can get, preferably 0.50, but 0.25 would do".
I see David Silver do oversize piston sets at £48ish. Before I go down that road I just thought I'd ask, does anyone have a set they're willing to part with ?
Steve
I know member andut recently had to go down the rebore route.
Might be worth checking with him to see where he got his parts from.
DS price for four piston kits is the best part of £200 with delivery and VAT, don't know whether you will find cheaper.
Thanks Chris,
Yes, looking around last night I've seen a couple of sets all around the £200 mark, anyone got any experience regarding the quality of the pattern parts ?
Steve
It may work out cheaper to gat a big bore kit. I saw one on fleabay a while ago for less than £200
Hi Steve,
I got oversize pistons from DS and so far all is well - As Mike says, a big bore kit would potentially be a cheaper option, but I didn't investigate suppliers or quality of kits etc - I didn't want to get involved in rejetting / dyno work that would be likely with cc increase.
Andy
Thanks for the info guys, I agree with andut about rejetting etc for what I assume would be a marginal power increase. Unless I hear different in the next week or so I think DS is the way to go.
Steve
Probably too late now but just came across these on eBay and remembered this thread:
http://www.ebay.co.uk/itm/HONDA-CB400F-CB400-FOUR-F1-F2-PISTON-KITS-0-5mm-NEW-PARTS-P11034-02-377-RiK-/151719631170?hash=item235331d942
They also have +1.00 sets.
Ouch, considering they're pattern parts!
Sent from my D2303 using Tapatalk
These are slightly cheaper than the parts from DS, which are what they call 'aftermarket parts' (so pattern then), and this price includes delivery.
Think the chances of OEM parts are slim and certainly unlikely at this sort of money.
Cruzinimage on fleabay. Superb price and good quality. Loads of people on here use them including me.
Sent from my GT-I9305 using Tapatalk
Thanks for spotting these Chris, I've been busy with other stuff so I still haven't got round to buying pistons yet but you're right they're a little cheaper than DS. That said I've never dealt with the company and I'm not sure of the quality. At least DS is a known quantity and I think I'd be more comfortable buying from a known supplier.
Cruizinimage... I've only seen Big Bore kits from them and that's not what I'm looking for. I emailed them and asked if they had +0.5 pistons and they didn't have any. After recommendations for them I was kinda hoping they'll have a production run shortly and produce what I want.
Regards
Steve
Agreed, they may be an unknown. From a quick look I found one reference to the company in other forums.
This quote came from RiderSite.com, from a guy apparently rebuilding a Triumph 6T:
"There are a few sets on eBay, but all the cheaper castings and mediocre rings. I know people who use them, but they don't use their bikes the way I'll be using mine. At £140, they were about £50 more expensive, but that extra buys me the piece of mind that comes with quality components. These two were found on eBay by a company called IMD Pistons. A few others had slipped the net by the time pay-day came around mind, but glad they did."
Thread at http://www.ridersite.ws/rs/viewtopic.php?p=106561&sid=265a6b8cbe278baffbf7b7a4d819a967, quote from page 6.
Yes, Cruzinimage stuff generally seems good but can't buy from there if they don't have the stock, and the big bore kit currently listed on their US site says it doesn't ship to the UK.
I got my RD pistons from CruzinImage for a fraction of the cost from Yambits (Yamaha equivalent to DS) and they are fine, much better than the Mitaka's I had before, Cruzinimage have a UK shop on ebay here (http://www.ebay.co.uk/sch/cruzinimage_uk/m.html?_nkw=&_armrs=1&_ipg=&_from=) but they don't have 0.5 only the bigbore (http://www.ebay.co.uk/itm/75-77-HONDA-CB400F-466cc-BIGBORE-PISTONS-KIT-WITH-GASKET-CI-CB400FBB-/252110798189?hash=item3ab2f97d6d).
Well I still have lots to do, the frame is away for powdercoat at the moment and I've not tackled the motor yet so I'm not in any desperate hurry but I'll certainly be keeping an eye on the Cruisinimage site in case the piston set comes up.
I reckon they may only offer the big bore kit, as lots of variants to consider as the 400 in japan was just under 400cc and Europe & USA was 408cc.
Ash
Ash
So what size would these (http://www.ebay.co.uk/itm/75-77-Honda-CB400F-Standard-Piston-Rings-Set-4-Rings-Set-Include-CB400FPR-/261954222975?hash=item3cfdb03b7f) standard rings be ?
Who knows you would need to ask what bore they are for
I'm thinking they are exactly the same.
"To comply with licence restrictions in France and Japan Honda also produced a 398 cc (24.3 cu in) version by fitting a shorter 48.8 mm (1.92 in) stroke crankshaft."
So what size would these standard rings be ?
Good question... I'd assume that they're to fit a standard 51mm piston.
I need 51.5 mm pistons and rings, however I do have another option..
I could ask SEP to make and fit new liners, then rebore to std size, then re-use my std Honda pistons with new rings.
Swings and roundabouts really, save on new pistons but pay for new liners ?
Steve
As it states the stroke is altered the bore will be the same. This (http://www.ebay.co.uk/sch/m.html?_odkw=honda+cb+400+piston+rings&_ssn=shira1171&_armrs=1&_osacat=0&_from=R40&_trksid=p2046732.m570.l1313.TR0.TRC0.H0.Xhonda+cb+400+piston+.TRS0&_nkw=honda+cb+400+piston+&_sacat=0) guy is worth keeping an eye on as he sometimes has piston kits, he has the 0.5 rings at the moment but not the pistons, I got a set off him for an FZR Yamaha a while back and they were fine.
Steve
To have a new set of liners made is not cheap.
I'm ressurecting this thread because I've acquired a set of oversize pistons, or at least I'm led to believe that they're oversize. I have no vernier gauges or the like to measure them but the guy recons they are 51.5mm when he measured them. They are genuine Honda but looking on the crown, I can see no oversize markings anywhere to show the size, are they ALWAYS marked with an oversize ?
My bores are STD at the moment but need a .50mm rebore and these pistons slip into the bores now. Surely they should be too large to fit ?
Maybe a stupid question but I'd appreciate some help
Steve
If there are no marks on the piston crown; The oversizes are sometimes cast into the piston in the pocket either side of the gudgeon pin holes.. (wrist pins)
HTH
Nigel.
I see nothing at all on the crown, either side of the pin theres just casting numbers 'S377' and '3'. On the opposite side just 'HONDA'
Steve
Steve
the tolerance on pistons is very close,
those pistons are standard,no other piston would get anywere near ,
Yes, I think you've confirmed what I thought. I'm going to see him tomorrow and get a closer look at that vernier gauge he uses ;)
Steve
Second picture (http://www.skylinesoftware.co.uk/400four15.html) down shows where mine were marked, or not marked in the case of one of them which turned out to be standard >:(
Thanks Bodd, big help, the markings are pretty obvious now that I've seen them!!
Steve
