Other Stuff => Misc / Open => Topic started by: Arch stanton on April 07, 2018, 08:56:52 AM
Are there any forum members who own or know anyone who owns a Cb175k0?
I may have seen a K0 at some point. But I cant remember doing.
Sean.
Very rare model. Never personally seen one in the UK. Very much a 175 version of the CB160 with chrome panelled tank etc I think a few members on here have the later 175s. I have a `71 K5 . I may be wrong here but I think I did see UK literature for the K0 though so it was possibly sold here in small numbers. I would imagine many cycle parts are common to the 160 The parts manual is actually on this site in my Dropbox links for the CB175K0 and the genuine Honda Shop manual.
Hello Ash.
I have 2 k6's & a sloper.
The reason I ask about the K0 is.
I have a perfect NOS rear mudguard for a K0.
Even though I have K6's the k4/5 model's are my favourite.
Sean.
Hello Ash.
Sean.
Here is the link to the K0 parts book... I am on the lookout for a 'sloper' centre stand if you ever see one. I have a '68 CD125 'sloper' which is basically the same as the 175 but with an SS125 type engine. RGP750 (Rich) on here has two late model CB175's, one of which he just finished restoring.
https://www.dropbox.com/s/5k0tcbyenikx50i/D1-Honda_Cd175_Cb175_Cl175_Parts_Manual_Catalog_Download_1967.pdf?dl=0
Sloper Centre stand eh.
You & me both old bean. Hopefully mine can be repaired.
Sean.
As Ash has said the 175 KO was essentially 160 with a slightly larger capacity, it did however have a 5th gear and a speedometer that incorporated a tachometer. I think it was only produced in 1968 and wasn't imported to the UK.
Probably most went to the USA and are popular there for the F160 racing series in view of the 5th gear.
Bore a CB160 + 40 and you have 175.
Yes ..I think you are correct Peter ..not available in the UK and pretty difficult to even get a decent image of one. Here's the best can come up with :)
[attachimg=1]
Not sure that the 175K0 had a separate tacho though although the CB125 did.
[attachimg=1]
This sloper is advertised as a 175 but appears to be 4 speed. Is this correct?
https://www.ebay.co.uk/itm/Honda-cd175a-Sloper-spares-or-repair/132566096355?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D49131%26meid%3D2354c7d9b76946ac83e89fce563de2b3%26pid%3D100005%26rk%3D2%26rkt%3D6%26mehot%3Dpp%26sd%3D112907582802%26itm%3D132566096355&_trksid=p2047675.c100005.m1851
It's a CD175A sloper which is 4 speed (6v electrics, no electric start). A much loved model & one of my 1st bikes.
[attachimg=1]
I'm thinging of putting a 5 speed gear cluster from a K6 into my sloper. But I'm not sure yet.
Also I'm led to believe the sloper generator puts out enough power to run 12v. So I just need to change everything else.
Has anyone here done either of these mods?
I like to keep things original. But I think these mods would greatly improve the little sloper.
Sean.
Back in the early 80's I converted a couple of CD175s (not slopers) to 12v, as the generator output is determined by the battery voltage. Changed the battery, ign coil and condensor, flasher unit, horn and bulbs for 12v items, job done! Worked perfectly for more than 2 years as everyday hacks, then sold them on.
I must get on with it. As the 6v system is far too weak.
I wish I could do the same with my Xl250 Motorsport.
That has 3 generator coils 1 for Ignition. 1 for Battery.
1 solely for the headlight, which is amazingly good.
But the Battery/indicators are amazingly bad!
I seem to remember that I just swapped all of the 12v electrics from a CB160 onto my sloper back in the day but when I sold it the buyer insisted that I swapped it back to 6V standard parts ? Alternators have come on so much, due to rare earth magnets. For a work project a few months back, I rewound an aftermarket HD 50A alternator with PEEK coated magnet wire for 250v output/three phase. We were pulling 1.25 kW from it when we tested it and the magnet wire was still within it's current rating.
I wonder if that CD175 sloper project on eBay is genuine mileage?
If the milage is genuine. Makes me wonder why the tank badges have been changed.
Also the rear tyre looks like a Dunlop SM. Surely a Sloper would not have scrubbed of its original tyre in 4k miles. Though it could have been changed out of preference.
But the tank badges???
I have two '69 CB250K0's that have 4.5k & 6k miles on them and they had the original Bridgestone tyres on them with plenty of tread left when I got them. You are probably correct to doubt though as most UK registered CD175's were used as 'get to work' everyday transport and usually have racked up 20k miles plus in their lifetime.
I use a CD175 alternator in my '66 Triumph instead of the Lucas original. That's wired for 12v, I use a decent size battery and 14.5v Zener Diode to stop over charging but the original Honda circuits which bring pairs of coils in as load goes up is Ok. I wired the Alternator on my Triumph to be full power all the time.
The original "Nippon Slipoffs" as we nicknamed them were frightening with the slightest bit of damp on the roads, most people changed the tyres after a first scary ride on a wet road. Probably explains why original stock tyres pop up on fleabay these days, often for stupid money, desired by those doing restorations, mad fools!!!!
Recent "barn find" rescue in Canada. All the important stuff is there, missing some odds 'n ends. Was running when parked, motor seems unmolested.
Get a load of those bars!
They are a funny bunch over there.
Yah, somebody must have thought they looked cool back the in 70s. On my list of things to do. ;D
Cables are in the "mystery box of parts" that all the best barn finds come with :)
Very similar to CB160
I love the phrase. ‘was running when parked’ .. honest mister (parked when, 10 years ago before the rust set in, engine seized and the seller nicked a load of parts..)!
I also got this from the same guy. I'm feeling lucky with the CB175 as well... :)
https://www.youtube.com/watch?v=OEA3DzNsGtY (https://www.youtube.com/watch?v=OEA3DzNsGtY)
https://www.youtube.com/watch?v=E48DcJn2zAQ (https://www.youtube.com/watch?v=E48DcJn2zAQ)
How to restore a barn find ... Step 1. Get it running. Step 2. Fix everything else.
https://www.youtube.com/watch?v=dYNaHCTC5lo (https://www.youtube.com/watch?v=dYNaHCTC5lo)
