SOHC.co.uk Forums => CB500/550 => Topic started by: SteveW on July 03, 2018, 04:43:16 PM
In the attached pic, there has never been a pipe on the outlet at the bottom, I'm assuming it should be blanked off?
Drain pipe ;)
Drain pipe ;)
So is it open all the time or does it have a plastic plug in it?
Drain pipe ;)
No plug, PN for the tube is 17335 323 000
The pipe (just fitted a new one) has a little bit of black foam (or the like) filter in the large dia. end. I never realised until recently and had to check it was there on my other bikes.
