SOHC.co.uk Forums => CB500/550 => Topic started by: AndyH on December 20, 2018, 09:23:13 AM
Contrary to some unsubstantiated rumours that I'd sold my 500K1, it's still with me! 8)
Something that's been annoying me for quite some time is the stiffness of the clutch lever. Engagement of the clutch itself is fine, with no "grabbing" or suddenness (is that a word?) so I think I've got the adjustment fairly right. I've removed the cable and checked that there's no problem there, but a few months back I replaced the various oil seals on the LHS. Perhaps I didn't put enough grease in the clutch lifter and adjuster assembly when I put the cover back on. The silly little grease nipple on the cover itself is NFG in my view.....I have a small nipple grease gun but I couldn't force any grease in. >:(
All ideas/suggestions on how to make the lever smooooooth gratefully received! ;D
Meanwhile, a Very Merry Christmas and a Safe and Healthy 2019 to all and sundry from "Down Under, West of Everywhere"!! :) :)
Always worth trying a new GENUINE cable, you'd be amazed at the difference compared to old ones or pattern parts.
+1 And make sure cable is routed correctly.
Thanks guys, I think you're right. I'll purchase a replacement cable.
Are "slinkyglide" worth a look or should I simply go OEM?
OEM will be the best available, tried many pattern makes over the years, but OEM always sorts it.
Here some details of a genuine cable. Compare that with imitation products... Never had one break. Replaced one after ca. 60.000 kms. The second one has done 75.000 kms now, but probably needs replacement soon.
Is pushrod in one piece?
KM's ? thought this was the UK :)
I change the clutch cable on my K1 every couple of years, as the 500 clutch is already heavier than the 750 and it does make a difference. I use DS cables, which seem to work well, however there often seems to be a shortage of supply so now, as with many other parts, I keep a spare on the shelf in the garage.
I am gradually building up a stock of spares for the old Honda's that I have and I even recently persuaded myself to buy a second sprocket carrier from CMS for the CB500 in case of future need.
It's in one piece Bryan. :)
Check that the ball is in the lifter and it is nice and round, a slight flat spot can give problems ;)
When I did the seals I checked the ball Trig. All OK.
I'll replace the cable (trivial cost when all said n done) and report back.
What condition is the clutch actuating helix thread?
http://forums.sohc4.net/index.php?topic=89065.0
If not already see if it’s routed above the left tank mounting lug.
When I altered mine to that route it seemed to help, and I think my old one was back in the 1970s.
Regards Jeremy
Left? ???
Regards Jeremy
Jeremy, can you inform us exactly how the clutch cable is supposed to be routed?
Regards Jeremy
I will check later,but I am sure it goes from the lever ,round the headstock,under the RH tank mount,through the hole in the frame next to the coils ,down between the 2 LH carbs,rubber mounts and onto the final drive case,.
try that ,keep the bends as wide open as possible ,the larger the diameter,the better
