SOHC.co.uk Forums => Other Bikes => Topic started by: SteveW on January 13, 2019, 01:23:16 PM
Title: RD350LC
Post by: SteveW on January 13, 2019, 01:23:16 PM
Anyone know anything about them, my mate has had one in his shed for must be at least 10 years.
Hasn't moved in all that time. He's now thinking of selling it so I may go for it. Think the engine needs a bit of work.
Title: Re: RD350LC
Post by: Nurse Julie on January 13, 2019, 01:47:07 PM
I can't remember any detail about mine back in about 1981, except it was black and fantastic fun to ride.
Title: Re: RD350LC
Post by: hairygit on January 13, 2019, 01:51:04 PM
Do some research on spares availability first. Yamaha used to have a policy of taking unsold spares back from dealers 12 years after production ceased, and crushing them! Check especially for availability of crank parts, including the labyrinth seal which often needs replacing when a 2 stroke has been standing many years.
Title: Re: RD350LC
Post by: Laverda Dave on January 13, 2019, 01:55:25 PM
The power valve model was the best. Problem area is the power valve servo motor sticking due to carbon build up. You should hear it whine when you turn the ignition key, they spin to clear themselves on start up. Likely to be seized if the bike has been standing so be careful. I ssem to remember the early 350's (non power valve) suffered cracked exhaust pipes at the cylinder head due to movement of the engine. Yamaha cured it by fitting damper rods I believe and I think these were also a dealer warrenty mod but I may be wrong?
Like any two stroke, be careful of any that have been radically tuned. The early bikes were used in pro-am racing and had a neat cockpit fairing.
Avoid the Brazilian built bikes, quality was poor, a mate had one and it was always seizing and the red paint flaked off the frame just looking at it.
Worth good money now👍, good luck with the purchase.
Title: Re: RD350LC
Post by: Rozabikes Tim on January 13, 2019, 03:15:59 PM
Barrels not out to maximum rebore like rocking horse dodo. Tanks rot out for fun. Brilliant bikes when runing right.
Title: Re: RD350LC
Post by: Bryanj on January 13, 2019, 03:48:23 PM
3 different exhaust mods under warrantee, water pump and oil pump seals go if left stood make sure it is a true 350 not 250 with 350 top end as there were a lot of differences.
If i had to have a bike fordaily use it would be a true 350LC as they were fun, fast and cheap to run but keep the oil tank FULL.
Title: Re: RD350LC
Post by: SteveW on January 13, 2019, 08:15:05 PM
Thanks for the info everybody.
One last question:
Has anyone got any tips on how I persuade the missus to let me keep it in the living room?
Garage is full.
Title: Re: RD350LC
Post by: Rob62 on January 13, 2019, 08:17:33 PM
If its an original lc i.e. not the later powervalve model, then they are rare, desirable and worth a lot so don’t  let it go for a song... ;)
Title: Re: RD350LC
Post by: Nurse Julie on January 13, 2019, 09:17:49 PM
One last question:
Garage is full.
Do the garage out to be the best, most sumptuous and relaxing room in the house. Move Mrs W in to the garage and all the bikes in to the house......good luck 😁😁😁
Title: Re: RD350LC
Post by: Allington (Steve) on January 13, 2019, 09:27:43 PM
One last question:
Garage is full.
Put a light shade on it and spread some avant-garde magazines on the coffee table
Title: Re: RD350LC
Post by: SteveW on January 14, 2019, 07:36:42 PM
Just been to have a look and from the VIN number its a 1980 RD250LC but the engine is definitely a 350.
Is this still a worthwhile investment or should i walk away?
Bike is in amazing condition.
Title: Re: RD350LC
Post by: Rob62 on January 14, 2019, 08:11:06 PM
Definitely worth having...join the rdlccrazy forum and ask for advice on its value (remember to filter the answers as with all forums 😄 ).... they also have a spares shop “the one stop lc shop” where you can buy just about everything and its good quality too. The guy who runs the site is a good guy and knows his stuff (norbo)...
Title: Re: RD350LC
Post by: SteveW on January 14, 2019, 08:20:37 PM
Thanks, will check it out
Title: Re: RD350LC
Post by: Allington (Steve) on January 14, 2019, 08:33:28 PM
Tons of 250’s were converted to 350’s and not worth anywhere near as much as a genuine bike
Title: Re: RD350LC
Post by: Rob62 on January 14, 2019, 08:45:57 PM
Sure it may not be worth as much as a matching numbers 350... but its still a rare bike these days and very sought after.... dont forget they only made these for 18 months or so before moving to the YPVS and many were crashed or raced.... There is a massive support network of spares for these old yams which is testament to their value.... If you decide its not for you, you wont have any trouble shifting it  8)
Title: Re: RD350LC
Post by: Bryanj on January 14, 2019, 08:48:56 PM
Vin number and engine number should be the same.There was a lot more to a proper conversion than just barrels and pistons like:-
Carbs
Reed valves
Full generator
CDI
Exhausts
Plus extra front disc and probably loads more
