SOHC.co.uk Forums => CB750 => Topic started by: theshootist on January 16, 2019, 09:04:03 AM
Hi,
Does anyone know whether the oil tank from the K series bikes can be fitted to the F1? I can see that the oil lines come out of the tank differently, but not sure if that procludes putting on the earlier tank.
I am sure that this question has been asked before by Phil ward and i put some pictures on the tread. The tank mounts and frame are different so, no. There are basically 4 tanks for the K and it is only the K0, K1 to K5 and the K6 have the same mounts ;)
Pictures in this thread >>> http://www.sohc.co.uk/index.php/topic,9048.msg62071.html#msg62071
Thank you Trigger - I did spend some time searching but didn't find that thread.
Looks like I will keep tothe later style.
