Other Stuff => Desperately Seeking!! => Topic started by: SPR on August 25, 2022, 05:55:32 PM
Title: CB500 spark advancer centre cam
Post by: SPR on August 25, 2022, 05:55:32 PM
Evening
So just started the change back to points before fitting the Hondaman system and fell at the first hurdle
This is what I have when I've removed the electronic ignition
[attachimg=1]
Apparently I think I'm missing the center cam of the spark advancer which is removed to install the alloy rotar for the electronic ignition.
The whole unit is 30220-323-000 which looks available here https://www.ebay.co.uk/itm/225064173947?epid=1713727851&hash=item3466dec17b:g:~6UAAOSwraNf8yL0&amdata=enc%3AAQAHAAAAoO2yhkUH%2FJi0NnsMLuTZ%2ByGvd2lwQPJhSSvX%2FeX0Sgh3rkDlOLxORYzU7V%2F5UE%2FN6YX8hUWIXs7lKcGsCNqIV1KhLVeIexNrZEVTV6AnVCbY195htb8oXYZqSXqMvm223cKIDryBfh9zlVQtbiC0klNU1pd0FDExj70PTcJ8fhcsMk0NEhY03luyKa%2FepnB3rLErRN35KWA9HwRBmjqJh64%3D%7Ctkp%3ABk9SR_KWnd7aYA (https://www.ebay.co.uk/itm/225064173947?epid=1713727851&hash=item3466dec17b:g:~6UAAOSwraNf8yL0&amdata=enc%3AAQAHAAAAoO2yhkUH%2FJi0NnsMLuTZ%2ByGvd2lwQPJhSSvX%2FeX0Sgh3rkDlOLxORYzU7V%2F5UE%2FN6YX8hUWIXs7lKcGsCNqIV1KhLVeIexNrZEVTV6AnVCbY195htb8oXYZqSXqMvm223cKIDryBfh9zlVQtbiC0klNU1pd0FDExj70PTcJ8fhcsMk0NEhY03luyKa%2FepnB3rLErRN35KWA9HwRBmjqJh64%3D%7Ctkp%3ABk9SR_KWnd7aYA) on eBay at £40 plus postage
It doesn't seem you can get the cam bit on its own ......
If anyone has the cam or a whole good unit I'm desperate as I'm snookered now till I get the part
Simon
Title: Re: CB500 spark advancer centre cam
Post by: Oddjob on August 25, 2022, 06:13:04 PM
What you doing about the contact plate?
Post by: SPR on August 25, 2022, 06:31:54 PM
I've got a new genuine Honda one
Post by: JezzaPeach on August 25, 2022, 08:55:11 PM
I replaced my advance plate/shaft and cam because the plate and shaft were fractionally bent due to the bike having been dropped and the centre small nut went slightly off centre when tightened.
I was fussy and it ran ok but either way the cam part (should be fine), base, arms, springs etc you can have foc. Only a c clip is missing.
This is for a CB500/4 K1.
I’m away until Monday. PM me if that suits.
Regards Jeremy
Post by: SPR on August 25, 2022, 10:03:37 PM
Regards Jeremy
Thanks Jeremy
Pm on its way
Post by: JezzaPeach on August 25, 2022, 10:26:39 PM
Need any more bits?
