SOHC.co.uk Forums => CB750 => Topic started by: El__burro on April 27, 2015, 11:55:07 PM
Hello, having to replace the fuel tap (due to a mission spout) I am looking for a replacement part.
Does any other model fit k2 version?
Regards
El__Burro
Regards
El__Burro
The fuel tap is the same as the 500, early USA 550 and the 750. I have some old taps that have tubes if you require one. MP me your name and address and i will pop one in the post to you ;)
Honda part number 16950-300-020
Notes Year Make Model Submodel
1974 Honda CB500 --
1973 Honda CB500 --
1973 Honda CB500 Four
1972 Honda CB500 --
1972 Honda CB500 Four
1971 Honda CB500 --
1971 Honda CB500 Four
1974 Honda CB550 Four
1973 Honda CB550 Four
1974 Honda CB750 Four
1973 Honda CB750 Four
1972 Honda CB750 Four
1971 Honda CB750 Four
1970 Honda CB750 Four
1969 Honda CB750 Diecast Engine
1969 Honda CB750 Sandcast Engine
Many suppliers of complete taps on ebay, plus Dave Silver of course. Don't forget you need the fibre washers under the heads of retaining screws or fuel will always leak past to the carbs----generic ones don't do the job as they are too thin and split, Honda ones are damned expensive I have used 6mm Dowty washers with success in the past but they aint cheap either
What size fuel pipe i need for a cb750 K2?
El__burro
El__burro
The Honda size was 5.5mm ID but, it is no longer available. 5mm ish ID will do the job, Link >>> http://www.ebay.co.uk/itm/Nitrile-Rubber-Smooth-Fuel-Tube-Petrol-Diesel-Oil-Line-Hose-Pipe-Tubing-Breather-/130740225601?pt=LH_DefaultDomain_3&var=&hash=item1e70b98641
5.5mm still available from David Silver
You will find it is 5.4mm, the same as in the link to Advanced fuel solutions ;)
Bought a 5.5 line.
1 meter should be enough I guess.
El__burro
