SOHC.co.uk Forums => CB350/400 => Topic started by: adriangsmith on October 19, 2017, 06:10:29 PM
Title: Rear wheel offsets
Post by: adriangsmith on October 19, 2017, 06:10:29 PM
Can someone please let me know the rim offsets on the rear wheel for a 1976 cb400f? A photo of the spoke pattern would also be extremely useful.
Sent from my LG-H870 using Tapatalk
Title: Re: Rear wheel offsets
Post by: Nurse Julie on October 19, 2017, 07:09:48 PM
The front wheel from my CB400/4, rear is the same pattern. Can't help you with offset, I don't even know what that is but my wheels have always gone round ok 😊😊😊
[attachimg=1][attachimg=2]
Post by: Laverda Dave on October 19, 2017, 08:55:52 PM
Be cheeky and call central wheels, they have rebuilt so many 400/4 wheels (including mine last year) they should be able to advise you.
Post by: Orcade-Ian on October 19, 2017, 09:35:02 PM
The rim is actually dead centre on both wheels, by that I mean that the rim centre line is exactly in  the middle of the hub between the spoke flanges, so difficult to get wrong.  This is true for both wheels.  There are no left side or right side spokes in either wheel but on each wheel there are 18 spokes which fit to the inside of the flange and another 18 which go on the outside. Close inspection of the bend will show you which is which - the slightly longer bend goes to the outside.  Lace all of the spokes into the hub, lay the rim on three blocks to raise it a couple of inches, look for any 'witness' marks on the hub where the spokes have previously been and the rim dimples will show you quite quickly the correct lay of the spokes.  Fit the ones from inside the flange first and then all the others.  Now turn the thing over and do the other side.
Sorry it's all words but the wheels I have just done are in the workshop and I'm afraid of the dark 🤓
I'll do my best tomorrow to take a pic of the lacing pattern but it's so foolproof even I can do it!
Ian
Post by: adriangsmith on October 19, 2017, 09:40:58 PM
Thank you all for your replies. Looking forward to getting this frame on the floor
