SOHC.co.uk Forums => CB750 => Topic started by: antonypo on April 24, 2014, 05:01:29 PM
Title: engine removal hell !
Post by: antonypo on April 24, 2014, 05:01:29 PM
i have everything off the frame,including carbs swinging arm and wheels, forks etc. saw a video that the engine can come out complete less the carbs, to the right but I'm struggling. I have now chipped a fin slightly so am worried to carry on .
What else can I do. ?
Title: Re: engine removal hell !
Post by: Trigger on April 24, 2014, 05:13:39 PM
Not sure what video you see but, it is easy. I do it by laying a 2" thick polystyrene sheet on one of the bike benches, then lay the bike on its right side . Unbolt everything and lift the frame off the engine.
Post by: MarkCR750 on April 24, 2014, 05:34:18 PM
Second that , struggled like mad getting the engine out with the bike upright, when it came to putting it back in I had heard of the laying the bike down technique , so easy took about 10mins.
Post by: Trigger on April 24, 2014, 06:26:28 PM
Yes Mark but, the next trick is how to move the engine about once out. Not easy with something that comes in at about 87kg.
Post by: Bitsa (Ralph Wright - RIP) on April 24, 2014, 06:56:02 PM
Trig is dead right alot easier with this www.sohc.co.uk/index.php?topic=4683.0
Bitsa
Post by: Trigger on April 24, 2014, 07:00:18 PM
Mine has wheel and rotates. And what do you do with that if you need to work on the sump? ;)
Post by: Bitsa (Ralph Wright - RIP) on April 24, 2014, 07:02:08 PM
You can lie it on its side real easy peasie Trig soooooooooo easy to move around.
Bitsa
Post by: LesterPiglet on April 24, 2014, 11:06:56 PM
I'm pleased I can manage my wee engine on my own.   ;)
Post by: Lobo on April 25, 2014, 01:55:27 AM
Anthony,
Sorry to sound obvious but have you removed the top breather cover, ... sump... and oil filter?
Not done the '750 but these bits definitely need to be removed from the '400F first. And it wasn't totally obvious .... it looked like it would come out with the breather cover on... but nope.
If no 2" foam handy you can try an old sheet on the lawn when you lay the bike over.
Post by: antonypo on April 25, 2014, 08:18:08 AM
took the oil filter off but the top cover wont come off as all the screws are hard down. However the book says just taking the inspection covers off is enough.
Looks like i need an impact driver then? I also though it didn't mention taking the cover off so as not to damage the rockers etc???
The video i watched (cant find it now) had the cover on too.
Post by: Trigger on April 25, 2014, 08:58:02 AM
Oil filter and inspection cover should be OK. To make it even easier, remove the sump pan. When fitting a engine i always leave the inspection cover, oil filter and sump off. This makes it easy not to scratch the nicely painted frame. Before you impact drive any bolt/screw from a old engine, spray them all with WD40 or Plus gas and let it soak.
Post by: Bitsa (Ralph Wright - RIP) on April 25, 2014, 06:57:49 PM
I have done this many times and you can argue all you like removing and refitting I have always done it with the top breather cover ON and the sump ON.Sump off for 400/4 dead easy.There is not alot of room but WITH a mate who has done it with you before POP.
Bitsa
10 years ago would have done it on my own and without a telephone box or fancy dress that has a FO S on it
Post by: SteveD CB500K0 on April 25, 2014, 07:01:20 PM
Sometimes I think you guys are speaking a different language...    :)
... oh, you are??
Post by: Bitsa (Ralph Wright - RIP) on April 25, 2014, 08:06:05 PM
Steve,
Glad you twigged it.I bet there are some out there got the thing connected to a beer pump as well right Trig??
Envy you never thought of that shit
Bitsa
Post by: Trigger on April 25, 2014, 08:09:11 PM
Bitsa, Whats a beer pump got to do with this . I thought it was about engine removal, and it is much easier with a nice new bench. O' and engine stand  ;)
Post by: Bitsa (Ralph Wright - RIP) on April 25, 2014, 08:16:26 PM
Yep
Dead right but a barrel connected to a pump while you are doing all this graft is perfect.Will look into that here will make cold wet shit weather much more enjoyable.You agree?
Bitsa
Post by: Trigger on April 25, 2014, 08:19:41 PM
Good idea Bitsa, Put a beer pump on the bike bench. Never thought of that one and cheaper than going to the pub.
Post by: Bitsa (Ralph Wright - RIP) on April 25, 2014, 08:25:47 PM
Spot on again Trig
Bitsa
Post by: MarkCR750 on April 25, 2014, 08:28:45 PM
Antony, I didn't take anything off mine except the carbs and oil filter, the only thing that made it awkward was taking it out with the frame upright, the engine is heavy and difficult to grip, I put straps around it and used a wooden beam with a person at each end lifting and me manouvering the engine, it took about 45 mins and was difficult to do, lucky not to get trapped fingers etc,  when I put it back in the engine was in the same configuration, however it was incredibly easy this time because I was able to manoeuvre the frame around the engine because in comparison it's light and easy to handle, I got a mate over to help me and it took less than 10 mins, I'm sure that removing the engine would have been just as easy if I had lain the bike on its side, so don't take anything off that you don't have to, your just increasing the risk of damaging something.
Post by: Bitsa (Ralph Wright - RIP) on April 25, 2014, 08:41:41 PM
Mark.
Seriously with a mate who's done it with you b4 POP.I know you are going to know all arse but honestly I have done all the 60s to 70s engines and most of them had to come out to get the head off etc real easy as most wife's,girlfriends would say its all in the wrist actions honestly it is.When you are ready stay cool with a mate and sorry to say most of it is up and under.Lift up at the front and slide the arse out and straight out the right side.Same going back but if you only do this once in a life time its a frackin nightmare
Dont kid your self this is going to be a git forget and just do it.
Bitsa
Even the little ones were a bastard 125,175.200 etc
