Other Stuff => Misc / Open => Topic started by: speedibee on September 20, 2017, 03:25:35 PM
In my haynes it says adjust gap B ,that is the screw and lock nut which increases the revs while the choke is on , but it doesn't say what the gap is supposed to be , the actual screw and nut are tucked away between the other mechanisms and would be too hard to get at while fitted to the bike ,so I need to know gap B before I fit the carbs back on .
Turn over the page to page 65, No.10. Is says 0-0.3 mm or 0-0.012 inch.
Thanks very much Nursie , I have found it right where you said it was ,,
Good, I did have to look in the manual myself, not for the gap size, sad as it may seem I knew that but didn't know the page number ;D
