SOHC.co.uk Forums => CB500/550 => Topic started by: Alex v on June 12, 2019, 03:09:49 PM
Hi got a 76 cb550 dropped the oil pan and 3 lugs of metal. Assuming these r off 3 or 4th gear.
Is it possible to flip the engine and strip without having to take the head off ? Any help is much appreciated thanks
If it's anything like the CB550, you can flip the engine and split the crankcase for a good look at the gearbox. Bill W.
Yes, you can. But, if you find the primary chain is knackered and has been attacking the internal oil gallery, obviously replace that while you have it open, but then you need to remove the crank, which can be done without removing the head, although you will need to remove the rockers/cover as well to release the camchain in order to get the crank out, and for the small costing the scheme of things, replace the camchain as well. Probably best to get a full gasket set, just in case you discover further horrors inside that may need the head off as well.
Thanks for both replies and I will deffo inspect both when open and replace as necessary 👍🏾 The bikes been stood for 20 plus years and fresh oil/filter and clean the points and it fired up first go no rattles and smooth as but discovered the lugs while cleaning the pan and read its common but will deffo b fixing and putting back on the road ASAP 👍🏾 So you’ll prob b hearing from me again lol
If it has been sitting for 20 years, you will find the rings stuck to the pistons and rust on the bores. Better to strip the whole engine ;)
Literally fired up first go but had to bridge the solenoid as the starter button is none existent lol tried to post a vid but says 3000kb limit
You could put it on youtube and post the link here?
