SOHC.co.uk Forums => CB750 => Topic started by: Pauarc on January 10, 2024, 10:45:34 AM
Does anyone know how to check if this shifter drum is the early one or later one as I can’t find any identification number on it it’s from a k2 engine
That looks to me like the later modified drum. The reason I say that is that the modified ones had a wider point where the gears were in the midst of changing. That is explained very poorly but I have a photo of the one that came out of my K3. Modified to give smoother change between gears as far as I’m aware.
Agree, later type.
I thought there was a bulletin on that in alladins cave which had pics on it
Sevice bulletin 750*40 in the dropbox, i knew it exixted as i still have the paper copy, hopefully a screenshot attached
Thanks Bryan, I knew I had read somewhere but couldn’t remember where.
No problem mate, i managed to collect most of the technical and service bulletins years ago which Ash scanned and put in either his dropbox or alladins cave, same as my very early parts books
Thanks for the help I had seen the Honda update (but couldn’t figure out how to measure it)
