SOHC.co.uk Forums => Project Board => Topic started by: RGP750 on November 23, 2018, 10:01:22 PM
Ok taken the engine out of the 125k3 it appears to be seized/stuck,
How do I get the head off, ? I cant seem to find anything on this engine.
Just downloaded a 125 175 manual but it is the later 175 engine (although it says 125k3) Grrr!
I need to split the cam chain but can't turn the engine to get to the link .
Am i having a senior moment ??
Thanks Rich
Not sure Rich ..that's a very rare engine ..not the same as the 175's and not a variant of the SS125/CD125/CL125 The man to ask is James Morgan as he's a bit of an expert on that model I think. I can email you his details (he worked for CMS at one time ...Coastpath on eBay ...he may even have parts to sell.
Looking at the parts Fiche Rich ...it is in fact loosely based on the CD125/SS125/CL125 with camchain tunnel down outside and almost identical camchain tensioner arrangement . A long bolt through the head ties the two cam covers together and two bolts fasten the camchain sprocket to the cam. The CD125 engine has a lot of similarities with the earlier Honda Benly engine.
That's great thanks Ash
Is there any way you can get hard copies of the micro files?
I think access to the cam sprocket is by taking off the points back plate and advance bob weights, these are stuck 'they should just slide off the shaft shouldn't they?
Any contact with someone with one would be great.
I PM'd the lead you gave me to the member on here but no reply as yet .
Cheers Rich
I have a cb 125 k6. How much are they similar?
Hi Menno
Images of a k6 on Google the engine looks similar.
can you put up a couple of photos one either side of the engine .
Thanks Rich
Emailed you scans of the CD125 engine manual yesterday, from work Rich. Engine looks very similar apart from points being on the crank on the CD. Basic layout looks the same though.
Thanks Ash
Just printed them off, hope to have a play later .
Thanks Rich
A bit of progress.
Stripped the maroon off and the paint was gold and white so that's what it will be .Think the engine may have had some abuse , Tapper cover has no thread and stuck on with what looks like Araldite ,no problem that i have a NOS.
Well need a re bore and pistons,of i can get these out Ouch! looks like a bit of fun coming .
Not taken the cam shaft out yet but lobes look good . [attach=1][attach=2][attach=3]
Hi Rich,
I have restored one and
Manuals for the K3 are rare.
James Morgan was no help to me.
I have a cb175/125 pdf file and a parts book for the K3 in pdf.
I will email them when home tonight if you want them
Regards
Andrew
Sent from my Wileyfox Swift using Tapatalk
Oh that's great thanks Andrew.
Cam bearing area is shot , will probably machine out and fit a bronze bush[attach=1].
Chances of finding a head are pretty rare i should think .
cheers for your help .
Hi Rich,
My pdf files are 10Mb+
And exceed the file size on forum
Not sure how to proceed?
Regards
Andrew
Ps attached is TBM 43J(https://uploads.tapatalk-cdn.com/20181126/a01618453fd97025fcd9f5619bf3997e.jpg)
Andrew. You can use a free file transfer tool called ‘wetransfer’ to send the files. Go to www.wetransfer.com. You just need rich’s email address..
Thanks for that James i'll pm you Andrew
Thanks James
I should have known because somebody sent files to me using that site
The mainstands were scrap
And the far East replica is 1 inch too short especially as the tyres
Are TT100's
Station X is a mile away
Regards
Andrew
Nothing wrong with wiping out Moss Side and the national computer museum is also at Bletchley Park.
Beat me to it Bryan. I went to Moss Side once (by accident) as I was supposed to be visiting Siemens/GPT
Back to the topic, my main stand has a broken leg.
Going to see if any other can fit.
I think it's the same stand as an upright CD175 Rich so at least not a mega rare part.
50500-303-030B
Hi Rich,
The mainstands are a weakspot the chassis is identical to the cb175k3-k6 including the main stand.
Can you believe the money breakers want for them ?
Regards
Andrew
Answering the location of Bletchley park it's within spitting distance of the station reputedly there was an underground tunnel
Between the station and park because there was so many documents being moved to London each day.
The tunnel exited at a platform
It was later filled in by railways staff after the war.
Regards
Andrew
There was also a airfield which is now lord grey school and the Leys going all the way to the old A5 and Westland helicopters at the bottom. I used to play in all the old buildings in Bletchley park as a kid, the only part that was occupied, was the main house that was a GPO training school ;)
That was cheap for an estate the size of Bletchley
I think that kinky Ken was on about 1 Westland helicopters sold as spares or repair ;D ;D
back on the topic was that a main stand?
Rats!! missed that
As Ash says all k3/4 and 175's had it,
Took mine off last night and it had been cut not broken ,Weird!
No great hurry one will turn up .
Oh Dear looks worse than I hoped .
At the mo thinking the crank may be toast as well :([attach=1][attach=2]
Anyone got a clutch?[attach=3]
Well Wish me luck with this one.
Been apart before, lots of lovely red hermatite everywhere.
Looks like it has been filled with sawdust??? no idea what it all is .
No sign of any recent oil either.
When the PO put it together he wouldn't have got first gear as one of the gears was on the shaft backwards so no chance of the dogs engaging.
Managed to shift the stuck piston with a few days soaking with WD and some heat and a large hammer and 40mm ally bar, didn't take that much effort.
Thats a challenge mate. Right up you street I'm sure ;)
Yes the thoughts of getting this wreck looking good again is what keeps me going ::)
Oh dear Rich ...I was toying with the idea of taking on that bike in a wild moment , as they are lovely looking little bikes ...kind of glad I didn't now. No worries though, you got the holy grail parts for it i.e exhausts and engine bits are bound to be out there somewhere.
If I can be of any help sourcing parts in Japan then just shout and I will ask Chris but shipping is going to be expensive...maybe France is your best bet ...I had to do the same for my CD125A sloper.
The only engine I can find in Japan currently is for a K1 but they are even rarer than the K3 so they have to be out there for the later model.
https://page.auctions.yahoo.co.jp/jp/auction/c671332893
Thanks Ash
Bet you are pleased you didn't take it.
Really didn't expect to find this inside looking at the outside.
I have another crank coming this week.
Getting the cam ground and the head re bushed.
Andrew on here with the K3 says some of the 175 gearbox parts are interchangable and i have a
175 box here so will check that.
Pistons, clutch plates ,cam chain adjuster wheels etc are available from CSML or DS
Be great to resarect this engine.
Thanks Ash
Sounds like you have a plan then. Where did you find a crank so quickly Rich?
Look at this CB160 engine my friend took apart recently !
[attachimg=1]
May be worse than mine Gulpl!!
just bought a really nice looking clutch complete. oil spinner complete and gearchange shaft for £50 then
he gave me 20 euros back for postage RESULT!!
Maybe a solution?
https://www.ebay.de/itm/Honda-CB-125-K3-Motor-komplett/152795006482?hash=item23934ac612:g:yewAAOSwR2RaEo9Y:rk:41:pf:0
Thanks Menno ,only just seen your reply.
Mine has cleaned up very well actually.
Amazing what can happen when someone carries out a "re build"
Take a look at the ill fitting head gasket, no wonder there was no oil in it,,helped to oil the outside of the engine. the gasket doesn't cover the oil return hole from the top end.
In it's past life looks like a piston has blown up, bit of work to do cleaning up the comb[attach=1][attach=2][attach=3]ustion chamber.
Sent the cam away middle of last week to David Newman Cams in Orpington Kent.
What a great company 4 lobes re-profiled and main journal skimmed .
Now just to get the head re bushed to suit the cam .
This bike had been severely bodged in it's history,loads of red Hermatite everywhere .
Take look what is appearing out of the oil hole that had the most wear.
Cam back in less than a week and £60 all in Result
Looking good Rich. Newman Cams are very good. Mike Newman is always happy to chat on the phone as well.
You have to work out how to make a bush that will not spin in the housing ;)
You could try Russell at J D Autoworx in Wallington, Surrey who may be able to make a bush with a suitable peg arrangement. Last time I visited he was developing a bushing arrangement for SOHC engines.
I found out recently that the CD175A and CB160 cam covers were bushed as standard Rich so Honda obviously achieved it. I suppose pressing in the bush if made slightly oversize with head heated and bush frozen would achieve a tight fit and you may have to ream slightly if the bush 'pulls' in a little. I would think it would be a hell of a sight easier than doing a similar modification to a 400/4 head but even that was achieved by Dixon racing yonks ago.
Thanks Guys
The Bush will be fitted as Ash says and a taper point grub screw will be fitted from the top after
the bush is fitted.
The tapping drill will go into the bush by .75mm Obviously it wont be tightened up too much because of the distortion risk.
but will stop movement.
[attachimg=1]
Found this contemporary advertisement from that era.
