General => New Member Introductions => Topic started by: HedgesJon on June 01, 2018, 12:07:06 PM
Title: New member
Post by: HedgesJon on June 01, 2018, 12:07:06 PM
Hello everyone,
I have a CB750 K7, I have been restoring it for the last new in my shed. When I bought the bike I was told that it was running and apart from the handle bars everything else was original. Well I felt a mug not to long into it.
Firstly found that the frame had been modified,then when I stripped the engine I found that someone had welded the lower and upper crankcase together. Also the wiring loom was,, well let’s say not quite right.
So anyway I am finally getting to the end. Electrics have been totally re-wired and are working just moving onto the seat and bodywork.
Cheers all
Jon
Title: Re: New member
Post by: haynes66 on June 01, 2018, 12:18:39 PM
pictures please!  and welcome to the forum...
Post by: Nurse Julie on June 01, 2018, 12:51:23 PM
Welcome to the forum Jon. Ah, welded crank cases, we get a lot of them through here, work that is,  so you are not alone. We'll done for getting this far and not giving up.
Post by: Johnwebley on June 01, 2018, 01:10:16 PM
   welcome to the fun forum,if you need help,and advice,this is the place to be.
 but we love lots of pictures ,
Post by: Trigger on June 01, 2018, 02:16:22 PM
Welcome to the mad world of the SOHC.
I have done a load of crank cases that have been welded together, nearly all still had the broken bits inside, grinding through the engine and destroying every moving part.
