SOHC.co.uk Forums => CB500/550 => Topic started by: mickwinf on December 30, 2020, 02:00:26 PM
I got this swing arm with a job lot, it has the open wheel end with the stoppers to make it easy to remove the wheel on the 4 exhaust models. The question is, is it a 500 four or a 550 k3 or are they the same? is there an easy way to tell?
No grease nipples in bolt so should be one in middle making it a 550 whatever, also the collar should have just one groove all the way round on each end rather than a spiral on each end, maybe top hat bushes as well.
With all that will fit either as the bushes and collar will be shot anyway
Thanks for info Guys, was thinking k3 as lots of the other bits were also k3
Missed those Ken, just looked at the obvious(to me anyway) bits.
Keep it safe
I have just found that the rear chainguard mount has broken off.
