SOHC.co.uk Forums => CB500/550 => Topic started by: ebmbiker on May 25, 2022, 08:22:28 AM
Good day folks,
I'm in need of the now discontinued part 22815-283-000 spring. I've Googled and no joy. Has anyone got one I could buy? If not, is there a known alternative or workaround?
Cheers, JB
Havent got a spare but its not a particularly strong spring so you can probably adapt something to fit
Good day folks,
Cheers, JB
Available from here?: https://www.theolouwesmotors.com/22815-283-000-spring-clutch-lever-cb450-cl450-cb500-4-cb500t.html
Almost certainly got one of those, saw one last week or so hiding in a box.
I'll see if I can dig it out. It's the one which goes onto the clutch worm drive in the left hand casing isn't it?
Thanks guys.
Oddjob, yes, that's the one. If you've got one I'll take it thank you
It is available from that link but at €25 postage!
https://partscatalog.eu/es/honda/p/22815283000-spring-lever-honda.html
Found one. Not in the greatest condition, a little rusty but still fine.
I'll send it down to you Friday, I should still have your address.
Absolutely brilliant! Thanks Oddjob
