SOHC.co.uk Forums => CB500/550 => Topic started by: Yodasoldier on August 11, 2015, 01:38:50 PM
Hi folks,
Been loving getting out in the sun on my CB550 :D
Noticed the rear sprocket was making a clunking sound occasionally and it looked as though there was a problem with the carrier. Close inspection (after dismantling) has shown that the sprocket carrier (flange) or where it fits onto the other part of the hub is worn as a previous owner has added a thin steel collar or sleeve which has broken up and is causing the clunking problem due to it being able to move slightly.
Would anyone know if wear on these parts this is a common problem ?
Is there a fix or should i be looking for a new hub?
Any help would be appreciated.
if its a replacement i need ....anybody got one or can point me in the right direction?
oh and one more thing...
This..
http://www.gentlemansride.com/ (http://www.gentlemansride.com/)
Ok quick update...
packed the cush rubbers with some cut to shape innner tube rubber, greased parts that needed greasing and reassembled....all seems good :)
are the cush rubbers available from anywhere? a search says no...
THANKS! my bike is a 1979 cb550f2 :) fingers crossed
Cheers Odd job!
That's great will see if they post to UK :)
one more part if anyone can help with, the back wheel has a D ring I think it's a flat sided oring. this appears to be very worn and could do with replacing . it is also an unavailable part from Honda.
cheers
I think it is an "O" ring just worn flat, do you have the part number as somewhere I have some old stock of some that may fit
Cheers Bryanj Part number is 91261323000 it is listed as a D ring 79x2.6
Thats a standard 500 four part and its not a D ring its an O ring 79mm ID by 2.6mm Xsect. I know i have some but can't get to my lockup till next week
Found the O rings 91261-323-000 Email me at blj@blj.org.uk if you still want one
I also have the bigger one under tha plate 91262-323-000 (92x2)
Thanks Bryan, have sent email and thanks to Oddjob, Cush rubbers ordered and on their way cheers to everyone else for the help.
Anybody taking part in this this year it's a great cause and and there should be a ride near to everyone up and down the country. Great excuse to get the bike out. A think I'll stick a post on the forum.
http://www.gentlemansride.com (http://www.gentlemansride.com)
Can't do Sunday as I work on Sunday night but wish i could
I owe you an appology, I just opened the bag of those "O" ring and they are in fact a D section not a round section, but still the correct part for what you want.
Yep the Danish site allowed shipping to UK ! Cheers ;)
