SOHC.co.uk Forums => CB500/550 => Topic started by: fazer1k on October 25, 2009, 11:29:11 PM
Would a Motad 4/1 listed for a CB550 F1/2 fit straight onto a K3 ? If not, can it be easily made to fit ?!
Thanks,
Ian
You will have to modify the silencer bracket/centre stand stop otherwise all fits ok
i am awaiting a reply on e bay for a motad exhaust with same question , i am after an exhaust for my k3 ,
is this the same exhaust you are looking at ? would be pointless to bid against each other
Hi Ian, i have a brand new motad for your bike,
If the seller is based in Hull then it probably is ? :)
Looks like there may be a a lot of interest, did you get a reply ?
Thanks Bryan.
yes mate hull ,
he does not know told me to get in contact with motad,
sure bryan will be right though, bracket will need a bit of modifying, 4 into 4 bracket i have would seem to be specific to the k3 exhausts
yes mate hull ,
Feel free to bid, I'm going to look at alternatives....good luck with the auction !
Needs altering as the rear footrests, to which the bracket bolts, are in a different place. Last one i did took 5 mins but needed a welder
Hi Ian, my location is Portsmouth Hampshire, thanks Darren
motad for 550 f models has M55H stamped on silencer, for 500 & 550 k0, k1, k2 & k3 has M5H stamped on silencer
