SOHC.co.uk Forums => CB500/550 => Topic started by: RGP750 on September 28, 2016, 08:57:50 PM
Hi All
Anyone have a spare spring that keeps the tension on the air filter /air box, part 3 on the attached
http://www.cmsnl.com/honda-cb500k1-four-england_model14660/partslist/F13.html#results
missing on the 500 i have just bought.
cheers Rich
I think Trig has one locked in his safe, he's looking to swap it for a CB750K2 cable guide for the bottom yoke please Rich ;D ;D ;D
They are tricky buggers to track down...
I managed to get one from USA. ...a guy was advertising the whole airfilter unit...so I asked if he would just sell the clip...luckily he agreed ...it cost 10 dollars plus about 10 for post.....a very expensive little item but I have learnt they don't turn up to often and when they do you need to go for it....
If that didn't turn up I was going to copy one...
Good luck...
I have a bit of wedge shaped wood that does exactly what the spring does, and cost nothing. You can't see it anyway so why worry?
Every now and again I look. Ordered some spring steel with a view to making. And I need THREE. But there are more important things and a piece of folded tubing has to do.
I sourced one from Australia recently can't remember the name of the supplier but I was lick cos I have a work colleague that carried it over the oceans
I know they are really hard to find though
My bet is that Rich will end up making them !
Just waiting for someone to lend me one ;) ;)
I will draw around one and pop in post Rich
Edit.....I will email it over now
Thanks Julie, just another project :D
Doesn't an '80ies XL250 clip fit as well?
