SOHC.co.uk Forums => CB500/550 => Topic started by: sgd37 on July 05, 2017, 07:34:38 PM
Hey guys!
I'd like to replace the tyres that came with the bike. So the manual says it takes front/back 3.25-19 /3.5-18 but I don't know what speed or weight rating I should go for. From the research I've done the Heidenau K34 seem to be the most appropriate.
Does any one have any recommendations? Can I fit a 3.5-19 on the rear wheel?
Much appreciated
As regards speed rating, you need "H" rated tyres, or "V" rated if they are designated for tubeless use, using a tube in tubeless tyres knocks the speed rating down one level. No, you cant fit a 19 inch tyre on an 18 inch rear wheel.
Try central tyres Birmingham the have Dunlop TT 100s in stock period for the bike
Thanks but I'm a bit far away from birmingham. Would S rating not be enough? I cant seem to find an 3.50-18 H online
No, "S" rating is 93 M.P.H. rating, you need at least "H" rated
Actually the site lists S as 112mph
https://www.oponeo.co.uk/moto-tyre-details/heidenau-k34-3-50-18-62-s-front-rear-tt-m-c#148861762
Not sure an efficient M.O.T. man would find that acceptable, you want something rated a fair bit higher than the bikes top speed, that is very close to the mark. I'd lay money Honda recommend "H" rated tyres for all the sohc fours. That said, it's your bike, and your life, if a tyre fails at speed, you could easily lose both. :o
Ill keep looking then. Could I use a 4.00-18 ?
I actually run a 4.00 / 18 on the rear of my 500/550's and don't have any issues. (Yet). I'm sure the more senior / experienced members on the forum will shoot me down. I run continental rb2/k112 and really like them.
M&P do good deals on a pair...
https://www.ebay.co.uk/itm/141307000267
I use Avons. 3.25 x 19 F.and 4.00 x 18 R.
Really good
Try http://www.vintagetyres.com/
I gave up trying to buy K70's for my CB750K4....it's a long story which lasted many months....and eventually bought Avons from Vintage Tyres.
A competitive price and they arrived next day with free P & P.
Only drawback was the cost of having them fitted to my loose wheels........£40 was a bit steep - but needs must.....and after the months long saga of getting Tyres, I'd had enough TBH.
I run a 4.10 x 18 Pirelli on the back and the stock size Pirelli on the front and I'm really happy with them.
Who told you about those James ;)
I run them on the 550 and 750
My 550 and 750 both have 4.00/18 on the rear
John, Do you have a source for the avons you use? and what name do they have specifically are they S or H rated?
Cheers everyone
Avon Roadriders. Love em, it's like a different bike with them on.
Dunno if it's worth talking about ratings on this thread?
The speed rating should be sufficient even if it's not that far above the max of the bike. It's tested for the tire design for a continuous / sustained speed at the rating applied. Seems to me they do this on a rig with the tire also loaded ( can't see if it's max load rating or typical average use) to make sure it doesn't fail under those conditions.
Interestingly, the tire manufacturers generally say that if the tire has been damaged, altered, underinflated or overloaded, then the speed rating would not apply, obviously! Many will not guarantee speed rating if a puncture repair has been made either as they have no way of controlling the technical aspects of the repair.
Exactly what the mot says about it someone with current knowledge would have to chip in about how or if they check speed rating against original specs.
The speed rating on its own seems to generate alot of differing views as to legality or if it's an insurance issue, in reality one of liability. There are views that say it's not stated in motoring law what speed rating should be used, only that the vehicle should not be driven above the tire's marked limit. It comes up primarily with cars when looking at winter tires as for example a tire with a V rating original fit may not be available in a pure winter / snow tire. They do fit a lower speed rating as the vehicle can be driven safely on this combination if you don't exceed the marked maximum.
There's another part of the spec that is relevant if not more important than the speed figure. It's usually placed in front of the speed designation (for example 66v) and gives a maximum loading for that tire.
This is far more absolute in terms of use as you don't reduce the weight placed on it regardless of speed driven. You can only load it upward as in adding a passenger. Overloading a tire will most likely make it fail.
I want a classic look so was looking at the Avon Speedmasters.
https://www.oponeo.co.uk/moto-tyre-details/avon-am6-speedmaster-mkii-3-25-19-54-s-front-tt?origin=shopping&gclid=Cj0KCQjwv_fKBRCGARIsAL6R6ei6Iy2pq3cZ6lztYK4_wkWgkrWZema28h5Anbz5mFvtOd_toRbYK3UaAhzuEALw_wcB
They have a speed rating of S which I suppose is minimally sufficient. They also have a rating of 212 kg. Maybe a stupid question but does this weight include the rider or is it just the bike.
Another member on here pointed out that the speed ratings of the tyres DS sells for the 400/4 (and CB350F, CB250/350K0) do not meet Honda's top quoted speed of those bikes.
The weight rating is all up maximum load, bike, rider, passenger and luggage, you add the total of the front and rear tyre rating, and stay well within it!
As far as I know (guess it assumes something like a 50 / 50 weight distribution) you'd add the two tires together and the total would have to support the bike and rider, plus passenger, plus anything else you carry.
You have to look at how they describe the weight capacity. I've recently put some on a car and they give load capacity in Kilos at 50psi, which of course you don't ordinarily use. So you have to understand what load is available at the tire pressure you run.
I was looking at it for the car to in effect work back through from tire choice to get a start point pressure for a non standard tire. I got them to weigh the car at our local dump on their calibrated weighbridge, then added people plus payload to get a start point.
The thing about overloading a tire is it builds up temperature quickly and either the tread delaminate from the carcass as the bonding goes over temp, or the carcass fails and deflates, fast, usually.
Mine overlapped as you'd posted there hairygit, I've obviously stated the same as you. Apologies.
No problem, great minds and all that!
If you want the classic look and value grip get the Continental RB2/K112 They are a classic 70's tyre but made with modern compounds.
Interestingly both my bikes have the same speed/load rating H
The rear last around 6000miles on the 750 and I often cruse along at 80/90mph non stop for an hour on my average commute
I tried opono and after six week no tyres and a fight to get my money back! Be carefull
Try these guys they do classic tyres.
http://www.wheelhousetyres.co.uk
Those Continental tires look really good on these old bike Mick, they make good quality kit I think. Continental that is, they do certainly have patterns close to original types.
I'm happy with them rain or shine not a scary moment yet. The rear on the 750 is getting a bit squared off now and twitch's a little on white lines now but its predictable
I just think old bikes with modern tyres looks so wrong
Have been running them for years Mick - I think I told you ha ha!!!
Has anyone looked at Bridgestone Accolade AC03 / AC04 tires as they have tread patterns they look in keeping with this era with ribbed front and conventional rear.
Think they fitted them as original on the Kawasaki W650 retro bike.
Could anyone identify these ones
Does anyone have any experience with the the ensign trials tyres?
http://www.ebay.co.uk/itm/325S19-ENSIGN-UNIVERSAL-MOTORCYCLE-TYRE-325-19-3-25-19-BSA-TRIUMPH-MATCHLESS-/260928465855?hash=item3cc08c6bbf:g:3cIAAOSwuLZY0p5e
They look pretty cool
I've always used S rated tyres, perfectly sufficient. Avon Speedmaster and SM very good in wet or dry weather.
(https://uploads.tapatalk-cdn.com/20170712/a6bf43636041c584b5c296402f6eb90d.jpg)
I like my metzler tourance(https://uploads.tapatalk-cdn.com/20170712/29795d2d9d79321ede1097fa69ec9684.jpg)
Yeah I think I will go with the Avon speedmaster safety mileage combo.
@Niko those tyres look cool for sure but I want something a a bit more retro. However I would like to know where you got that seat.
I always ran Avon sm mk11 on my bikes once I'd come across them good tyres in all weathers, up to and including snow, long lasting too. Fronts either Avon speedmaster or sidecar triple duty. Handily my solo bmw and sidecar cb500 and even my cb550k3 all carried the same tyres, 4.00 / 18 rear, 3.50, 19 on the fronts. My bmw even stayed sure footed over the Brecon beacons in 4 inches of snow and still falling a few times the year my wife was in uni before we moved in together. Not bad at all for an 800cc tourer sans sidecar, and I wasn't particuarly hanging about despite the snowfall. Really put my modern Honda ca125 and cb250s to shame, modern tyres are fatter and don't grip for toffee in even the slightest whiff of snow or ice, not that great in bad rain either ( Pirelli city deamon tyres I mainly used as cheap in that size and often come up part worn)
I like to keep part worn sm, mk11 tyres a few years in the shed to harden them off a bit, seemed to get a few more thousand miles out of them that way, when I treated the cb500 to a new set they seemed to wear faster than old part worns, though that bike did bring out the hooligan in me, K&n filter and probably re jetted by previous owner, and very free flowing exhaust made a recipie for abusive wheelspins and sending the whole sidecar outfit sideways through corners for fun, not nice to the tyres but immense fun.
eBay cheaply....
Hi Guys, I too am looking to change my current set up of an100/90 x 19” Kenda Challenger front tyre and a Chen Shin 4.00 x 18” rear tyre which were fitted prior to me purchasing the bike . Whilst both tyres do have good tread left on them I do feel the bike doesn’t handle as well as it should and it has a slight bouncing feel at around 40mph on the front, which I suspect is an issue with the front tyre.
The stock tyre size for the CB500 is 3.25 x 19 front and 3.50 x 18 rear, however some people are suggesting a 3.60 x 19 front and 4.00 x 18 rear hence I am looking at replacing both tyres with Dunlop K81 TT100’s if this is possible?
Dunlop's tyre fitment guide suggests fitting a more modern ‘Arrowmax Streetsmart’ tyre but I would rather keep with the traditional lines of a classic tyre if this is possible.
I have wrote to Dunlop and they are unable to advise re the fitment of any tyre that is not of standard size i.e. the TT 100's and therefore recommended I opt for the 'Arrowmax streetsmart'. I fully understand their stance but thought that as the TT's are their tyre some help may have been in the offing.
All help/advise much appreciated
TT 100's for the 500 are 3.60x19 front and 4.10x18 rear, you will wear out at least 2 rears for one front.
The 550 went to a 425/85x18 rear which will last a bit longer.
TT100's were/are in my opinion the best tyres for the 500 but as soon as the rear tyre centre tread gets to the limit of 1.6mm(I think) the tyre is illegal
I'm running Avon Roadriders on my 500. Used to prefer these on my old CX back in the day, and always trusted them in all weathers, so stuck with what I have had good, previous experience with.
It is only cars, van and LCV that they changed to 1.6mm, motorcycles still stands at 1mm.
I've run almost all of my 1970's bikes on TT100's since...the 1970's. Replaced a rear on the CB500 a month ago, the front has covered around 8,000 miles and is still as new. To me, they suit these bikes perfectly.
Cheers Guys for your help and advice, I presume you have fitted them onto standard size rims?
In the case of all of my bikes, rims have always been standard size D.I.D. originals or their replacements.
This I don't agree with at all as tyres lose there ability to grip the road as they harden with age. The tyre on my pegaso was around 6 years old when I eventually got it back on the road. It was OK in the dry if a little vague. But when I was caught out in the rain it was just outright dangerous.
I don't recommend keeping old tyres even if they look OK
It was broken down for HOW long!
I was running on a sidecar so had 'stabaliers' but I do find it varies according to who made the tyre, and when, some are so grip focused that for instance my dads bmw ran Conti Tour tyres, it wore the last one out in 3k miles, previously they had lasted 7k + per tyre dad complained to Continental tyres and was told the market demanded more grip, there was nothing wrong with the tyres before and 3k from a rear tyre makes a bike prohibitive to use.
I know what you mean about old tyres being sometimes very dodgy to ride on, my Suziki Gs125 was a 1982 bike, and when I first had it had her original bridgestone tyres, probably still with 90% of the original air, they were truly horrid in the wet but as a poor student I had to keep using them and the bike needed carefull handling being on 20 year old tyres. Drum brakes both ends were no help. I eventually saved up and bought a complete front end off a disk braked bike and grafted that on.
The seat of your pants will soon tell you if the tyre is too old to be much good even in the dry if you know that feeling, or just dig a thumb nail into the rubber, the feel tells a lot. Proper storage of tyres makes a major difference to their shelf life.
Far too long to remember. But when I'm busy I don't know were the time goes. It could be anywhere between 5or10 years ???
The super sticky tyre on my Guzzi only lasts about 2500miles on the rear and is totally crap in the rain it doesn't make a very good touring tyre
My GS125 had its original tyres on it when I bought it But I soon replaced them after running into the back of brand new Mazda RX8
