General => Site Feedback / FAQ / How to... => Topic started by: tangerine on August 28, 2018, 05:37:57 PM
I am re-instating the wiring into a new standard ignition switch. The connector on the loom was removed years ago ( after an attempted theft). I need to know which coloured wire goes where on the connector block. Any help gratefully received.
K7 wiring diagram should help
[attach=1]
Thanks for the diagram. I have identified the wires to go in the connector. It's now which wire goes in which position to connect to the correct spade connector on the ignition switch side.
Unfortunately, the diagrams do not give the orientation and type of connector.
Image attached of a K7 ignition OE connector, rear view
that looks like a great deal of help. Thanks BigAl
