SOHC.co.uk Forums => CB750 => Topic started by: Redders33 on April 30, 2020, 04:51:17 AM
Hello everyone hope you are all well.
I took my carbs off to clean/ check and they are flat slides when I expected diaphragm is this the case for a 77 f1 or have they been changed at some point?
Hello Redders.
Yes I am very well thank you.
Re, Carbs.
I don't know what Carbs you have.
But they ain't F1.
Only sohc with diaphragm carbs is one of the 650's
Here you go F1 carbs
(https://imagizer.imageshack.com/img922/3361/vo8dNZ.jpg)
(https://imagizer.imageshack.com/img923/8306/xdi8FM.jpg)
That's em Dennis thanks
Where you confusing the choke slides with the throttle slides?
Had us going there. Some have fitted flat slide carbs ($$$$).
