SOHC.co.uk Forums => CB500/550 => Topic started by: philward on December 21, 2020, 03:19:54 PM
Just dummy fitting new harness and having a mental block on the electrical connection blocks on the mounting bracket under the LH side panel.
Top connection is from the loom, middle from alternator/nuetral/oil presure sub loom - but what goes into the bottom connection block?
Sorted and mental block dislodged! Obviously rectifier but god knows where it is - remember testing it and repainting
I can't seem to locate the rectifier off the 500 (I refurbed and bagged up all the electrical components about 4 months ago - I am sure I remember repainting and cleaning the wires on the rectifier but can't find it now). I've got a spare from the 750 that I am sure I had to change because of a charging issue on the k6 cafe racer I built.
So I've tried to test it using the diode setting on my multimeter.
I'm testing across the green to each yellow lead with black multimeter lead on green and red lead on each yellow wire on rectifier connection block - I'm getting a reading of '592' on each yellow and if I reverse the multimeter leads, I get the same reading. This doesn't seem right getting the same readings!
Am I testing it correctly?
I thought the middle block on the K0 was round pins?
Also check the fuse wire, it looks to me to be showing signs of melting in the past.
Not sure what you mean about round pin on K0 Kens? Mine's a K2. Will check the fuse wire
Ken only the early K0 had the round pin blocks.
I thought it was all of them Bryan, odd that Honda would change it mid run so to speak
Oh my mistake, I thought Paul’s was a K0 for some reason.
Have you started on the Christmas Port early Ken? Wrong model, wrong person (Paul>)!
Any guidance on testing the rectifier?
Found a post from Mike explaining test process
Followed Mikes advice as follows (with rectifier completely disconnected)
'Establish which is positive of the rectifier and which is negative.
Using a multimeter on the diode range (or ohms range if there's no diode range)
Put the red meter lead on the negative and test each yellow lead of the rectifier in turn. Then do the same tests with the black meter lead on the negative.
You should have a reading on all 3 in one direction but no reading the other direction.
Now put the black lead on the positive, check all 3 yellows .
Do same with the red lead on the positive.
As before, a reading in one direction but nowt the other direction.'
However, I get a reading (diode range) when putting red meter lead on neg on rectifier AND with black lead on rectifier negative
I get nothing when putting black meter lead on postive or the negative rectifier lead?
Hey changed cos the spades make better contact and dont melt as easy
That's as it should be. You're measuring through all six diodes in one go.
On the countdown now Mike.
Wot?
Thanks Mike - this one came off the K6 project when it wasn't charging - changing for a spare cured the problem but if this one is checking out ok, it was maybe just a dirty connection that was cured when the alternative rectifierwas plugged in.
Anyway, its a result that this ones working (still don't know were I have put the original 500k2 rectifier though - too many spares for too many bikes!)
Thanks again
Don't rely on testing all six diodes at once (positive to negative).
The worst case scenario is four of the diodes are duff and you're only reading through a pair of diodes connected to one phase. In that case, you'll get charging but not a lot.
Certainly not enough to have any lights on.
Haven't tested pos to neg Mike - tested as per your recommended way but
'I get a reading (diode range) when putting red meter lead on neg on rectifier AND with black lead on rectifier negative
I get nothing when putting black meter lead on postive or the negative rectifier lead?'
Am I missing something in my ignorance?
Wot?
To 2500
Some verbal diarrhoea on my part is called for at this juncture.
Or you could become the Christmas Jedi. :)
That's the plan....
Anymore guidance on full testing relative to my results in previous post then Mike?
Measure each diode individually. You don't even need a meter, a battery and bulb will do. Remember that diodes only conduct in one direction so check each diode both ways. That's 12 checks.
Just ask if you need more advice.
Thinks.. maybe I need to make a video.
Thanks Mike - I have checked the diodes based on the your previous advise and got the results posted earlier. Sorry for my ignoranace but what wires do I need to test as per your last post? Sorry to be a pain!
You've got 5 wires. 3 yellows, a red and a black (or green)
The yellows come from the alternator and the red, black go to the battery via the voltage regulator.
To check each diode in turn, using a multimeter on the ohms range, or the diode range. Or you can use a battery and bulb set up.
The diodes only conduct in one direction, which is what you're looking for.
Put a meter lead on the negative and check each yellow in turn.
Put the other meter lead on the negative and check each yellow
You've now checked D1, D3 & D5.
You should have a reading one way but not the other way
Put a meter lead on the positive (red) and check each yellow.
Put the other meter lead on the positive and check each yellow again.
You've now checked D2, D4 & D6.
If it checks out, good. Put it back on the bike.
