SOHC.co.uk Forums => CB500/550 => Topic started by: captaindonutbikes on December 13, 2009, 11:09:23 AM
whats the best set up? had a look on the the singles forum but not really a clear answer (unless i can't search properly ;D)
thinking of getting a Boyer Bransden Honda 4cyl Micro-Power Ignition?
feedback much appreciated.
This was covered on the US site have alook here
http://forums.sohc4.net/index.php?topic=62195.0
Basically, Boyer in UK as it is more readily available and Dyna in the States for the same reason.
Seamus
I
There was another system called 'Lumenition' which had the whole system mounted behind the points cover.But it was affected by the heat of the engine.
