SOHC.co.uk Forums => CB350/400 => Topic started by: McCabe-Thiele (Ted) on July 25, 2021, 04:57:49 PM
I'm presently cleaning up the rear brake mechanism parts ready to fit before the rear swing arm eventually goes into place.
There is a bend in my rear brake rod that could be just how it was built as it looks such a nice curve or the PO bent it when he fitted it together as quite a few parts were not fitted currectly e.g The right hand front fork tube was 180 deg out.
I checked the parts manual - it shows a straight rod - however the parts manual also shows the brake pedal on the right hand side of the illustration with the pedal mechanism the wrong way round.
So do I need to warm it up & straighten it before I proceed to give it a coat of silver paint?
(https://live.staticflickr.com/65535/51334260676_857be32fb6_b.jpg) (https://flic.kr/p/2mdeveW)rear rake drum rod (https://flic.kr/p/2mdeveW) by Macabe Thiele (https://www.flickr.com/photos/187487200@N03/), on Flickr
It should be straight Ted but the do bend very easily. Just straighten it out the best you can.
Thanks NJ I'll do that might warm it up a tad when I do.
If it bent cold straighten it cold was the rule i was told
Thanks Bryan for some reason I thought heat might minimise any stress in the metal - if it bends easily as Julie says I will do it cold.
Yes, it bends easily when it's not meant to but I wouldn't know if you bend it back hot or cold 🤔🤔🤔Don't snap it 😭😭😭😭
Did it cold now its relatively straight !
