SOHC.co.uk Forums => CB750 => Topic started by: mikal on October 19, 2022, 03:09:06 PM
Theres a tasty 750 just been put on fleabay and Car n classic....and I am thinking....both nice and nicer price. BUT the colour isnt for 74....(but I do love blue, especially on the 250) and the seat isnt original.... Should this really matter??? Hopefully I can some response as I think it'll go quick.
I currently have a 73/74 550 that it will replace as its small!
If this is the one you mean, it's a USA import made to look like a UK bike in the wrong colour, wrong clocks etc, etc. For what it is, it's an awful lot of money. Lots of pattern aftermarket parts fitted.
[attachimg=1]
Yes thats it. Oh dear.....to my untrained eye, it looks nice, but then again.....perhaps thats why it was done like this, or this "elderley gentleman" was lazy.??
Yes thats it.
That sort of bike is fine if you don't mind paying top money for a USA bike that isn't correct. It'll cost you quite a lot of money to make it correct, there is no such thing as a cheap, perfect bike.
it does look nice tho....perhaps thats why it has been done like that. I currently have a very early US import 550 is too small for me and not enough POWERRRRRR. Was just a thought. perhaps I should look around over winter! Cheers.....sniffle sniffle...
Yes, at a quick glance it does look nice but it's not correct. It seems to have become a trend over the past few years for some people to do a bike up, regardless of if its correct or not, just on the off chance someone may fall for the bling. If that's the sort of bike you're after, then fine but why go to the bother of restoring the engine and then button it up with non standard Allen screws and fit micky mouse clocks and seat, the wrong back end, the wrong colour paint etc, etc ? 🤔🤔🤔. The answer is, it's a cheap fix.
Agree.I would have bought it but for the paint. Why the heck didnt the restorer simply paint it in the correct colour for that year. Shirley (sic) that was just as cheap?? Confused.com TY for the replies. I shall wait and see what comes up and treat myself to a cb750 for crimbo.
To the untrained eye looks like a descent bike!! Wrong side cover badges and wing logos. Front tyre fitted against rotation arrow.
you must look past the bling.
Not just the wrong colour but, wrong tank. That tank is for earlier K's
CX 500 tank badges :o
Micky mouse clocks
Tons of wrong bolts and nuts
Escutcheon missing from seat lock
Don't know what seat that is
Missing correct oil pressure switch lead
Wrong air box, from a K1
And i could just go on all night ::)
I have forgotten it already....LOL
Looks like the engine has been stuck together with glue or mastic or suchlike as well as a gasket 😳😳😳
[attachimg=1]
That in itself is reason enough to stay at
least a “barge pole” away.
Unless offered at the ‘right price’……make an offer?
(Attachment Link)
Looks like the engine builder has used Wellseal Julie, same colour and it oozes from the joints. Why!
Wellseal was well thought of in the 1960's - did it come to the market via Aviation development?
Blurb says:-
The complete answer to sealing problems on machined faces.
Non-flammable, has easy partability and is non-hardening. Formulated to give the best possible sealing performance under a wide variety of conditions.
Features and Benefits
• Can be used to seal threaded connections as well as flat- faced joints
• Can be used with or without a gasket, depending upon the design of the assembly
• Highly resistant to the majority of commonly used fuels, lubricants and coolants and is non-corrosive and free from abrasive fillers.
That maybe so Ted but you shouldn't need to use Wellseal on a Honda, the joint faces are both large in area, flat and most joints also have locating dowels. I use Wellseal on my old Triumph engine but that’s because the joint faces are so thin (the rocker box joint is a perfect example). It looks terrible on the Honda oozing out of the joint, they could have wiped off the excess with some meths. It just highlights the standard the bike has been 'restored' to.
I believe Wellseal and Hylomar were both invented by Rolls Royce aero. RR also developed carbon fibre when they were designing the RB211 jet engine in the 70’s. They invested so much into carbon fibre technology it bankrupted the company.
I would always use Hondabond on the casings - I can understand someone old school using Wellseal elsewhere - yes they should have cleaned off the excess.
It was the Rolls Royce RB211 fan blade that they were going to make out of carbon fibre was it not - a sad end until firm relaunched as Rolls Royce (1971) Ltd.
I remenber it well as a disgruntled staff RR member put out a rumour that the Derbyshire Building Society would go bust - that led to massive queues in Derby as members withdrew cash. The Derbshire Building Society survived the run until 2013/14 after takeover by Nationwide.
100% agree Ted. I always use Hondabond but not Wellseal, maybe he used Wellseal beause it is a lot cheaper than Hondabond (and doesn't go off in the tube despite covering the end with a piece of rubber glove :()
Maybe he used Wellseal because that's what he's had in the garage since the 1960's, probably the exact same tube 😁😁😁😁
Well its gone from fleabay and C&C
Frugal chap, perhaps inherited a half used tube ;D
Waste not, want not and all that.
Careless gasketing costs lives etc (ok, I made that one up ) I didn't get were I am today by being frivolous with gasket goo ;D ;D ;D
Hey! I’ve got an old tube of Wellseal in my cupboard 😂😂
I'm not surprised John, you obviously have to look after and cherish almost every empty tube where you live 😂😘😘😘
https://www.ebay.co.uk/itm/165728918959?hash=item2696369daf:g:AugAAOSw6phjTFvx&amdata=enc%3AAQAHAAAAoG53ythOOsKhGYnOBc4Udto1jeBi78ZuzFQDNSPMWiygj9pSOL5Rk7GFfOE6TIulsBCNIxCZ5%2BSY09XvMXJn2H5YUfaW%2BWXUWh7ZSqo%2FCg83TK%2BGjdBDYUbHBeD3DkbcbmfSeQn5POvAybCIZAYxSsgWGxTXNeoRls72hduYH1Z1NF1dVFG16MQ%2F9ZIStCL%2B89PQyDNdJR8jZ%2FPnN9yeR3o%3D%7Ctkp%3ABk9SR5Dg8a3_YA
I quite liked this just cos of the state of it. I have no knowledge set like you guys on here but didnt think that was over priced for what it is or am i talking utter pap?
FWIW if that is the original VRM pretty sure you cannot retain it. I think you can only retain a mark now when it's out of the DVLA for sale list or it has been retained previously.
I might be wrong but I have had instances where I could not retain or transfer an original VRM.
I have no idea if the price is a fair one.
Wasnt really bothered about the plate but it just looked about right for my level of knackeredness and the money. The seller has listed it as black and it clearly isnt but it seems ok for the brass. I'm expecting a cheque when I get home.............mmm, might be temoted at that. Whatever I get it will have to be cheap and for the money that didnt look too bad. Never going to be a show stopper but I rather liked it.
DVLA list it as gold?
Not sure if it's a trick of the poor image resolution but it looks like a sandcast - can't be at that price.
I did ask the question as I wouldnt know how to spot a sandcast and asked how to identify one but nobody came back to let me know the differences, probably couldnt be bothered.
Still quite like that though.....
It's not a Sandcast Ted, it's a total Mongrel, the buyer has been honest with his discription . A bit worrying that he calls it a 76 and a 78 though 🤣🤣🤣🤣
I like a mongrel, at least you dont have to be precious about it. So why ISNT it a mongrel Julie? What are you looking fir?
Sorry Roo, could you repeat that please 😂😂😂😢
When I have seen Sandcast engines the fins always seem to look flatter & smoother somehow - that was my opinion after seeing one at the Stafford Show.
They are totally different Ted. Sandcast head and barrels and crank cases are as rough as a bears arse and that's just one difference ☺️☺️☺️
Maybe the one at the show had been over polished then - it seemed to have fewer casting web marks as well. It looked super Matt.
The bike in the advert has a K6 engine in it by the looks of it, maybe even later.
Soz Julie, late night and up since 4am here!
Why ISNT it a sandcast then, what am I looking for ?..............not that I'm looking ;)
DVLA states 1978 regd via VRM if that helps.
A sandcast is a 1969 production bike and has VIN number up to production number 7414. Anything after that was a K0 die-cast.
The bike in question, as the seller says, is a 1978 F1 model with loads of bits off of an earlier K models. It is a UK registered bike but many of the parts on it are from a USA model, ie, the back end.
Makes one wonder if the V5 shows it has been a cat C or similar or previous owner damaged the frame so used an earlier frame. Could even be a ringer.
He does call it a Bitsa? US rear fender still cheap entry price into the 750 species is it not?
Easiest way to spot a sandcast is different number of screws on clutch cover but cant remember how many
Exactly, a bitsa or a Mongrel as I call them.
Also, Bitsa was a venerable member of this club (RIP).
We don’t have any members called “Mongrel”
☺️☺️☺️☺️☺️ True Steve.
I prefer Customised to Mongrel plus Mongrels can make the best pets.
As a non precious member, stone me public ally if you like but I quite like it and wouldn’t mind a crack at that tbh but struggling to work out mental ‘shed Tetris ‘to even consider getting it in my workshop. Maybe next year cos I’m deffo not selling anything to make room, that’s not fair!!🥲
I was aware of the 1969 thing but not of the engine numbers, nice hint. I shall get my head into my 750 book when I get home and do some swatting on that subject.
Rose tinted glasses but an inexpensive ride that looks used but not knackered to me….
Shed Tetris.
I thought Roo meant Shed Tantric?
No Ted, keep it in yer pocket! ;D
