SOHC.co.uk Forums => CB750 => Topic started by: clinto on November 14, 2022, 04:48:54 PM
Hello,Been using the search box to find correct fuel level in the bowl.No find.
Went through the online manual covering mine and it shows a gauge being used.Where would I look to find dimms of such gauge?
I do prefer to use clear tube on adaptor from drain ,is there a measurement for that?
Thanks in advance
Have you tried the Honda shop tech on Ash's drop box? possibly got what you need in there..........
Ta,Thats where I was looking,I'll have another gander
Honda never gave a level for clear tube, you will have to try and find somebody who has worked it out, gauge ebay item 354264213876
Looks to be 26mm according to the web.
Thanks for replies ,found it in the Greenbushacre info
They used tubes installed on endurance racer in the 1970s to give quick check and diagnostic view
[attachimg=1]
Can be seen above, later replaced by clear float bowls (don't you love lateral thinking) for same assessment.
