SOHC.co.uk Forums => CB500/550 => Topic started by: commando1954 on May 25, 2023, 08:42:28 PM
Can anyone recommend some good pads for my 1976 cb550 k2. I have new brake lines and piston seal but the front brake is crap.
I fitted Brembo to mine not expensive (£34 in 2022) with a good feel to them - can't comment on lifespan as I fitted them before my strip down.
What are you comparing it to?
The standard pad from DS.
Which is s#1t….
Compared to my 1973 cb750 which i believe is the same brake.
Nope, 750 has bigger disc, different caliper and pads.
500 should stop well if everything is free and greased with good pads, hoses and master.
I always used vesrah normal pads and found them ok
Also different arms x3. Different calipers X2 and a number of different forks fitted to the CB750. All a long way off from the CB550.
