SOHC.co.uk Forums => CB500/550 => Topic started by: gary123 on July 07, 2023, 06:14:27 PM
Just sorting out bits and pieces for my next project and "dry fitted" the rear hub using the parts that came with the bike (500ko).
It all goes in ok and looks centred but leaves no room for the chain adjusters, can any body spot what might be wrong.[attachimg=1][attachimg=2][attachimg=3]
Take out the left hand spacer and show a pic of it Gary, looks too long to me.
I gather you've had the hub apart?
Hub was apart when I got it. I think your right about the left hand spacer.
I pratted about all afternoon with it and as soon as I put the pictures up it looks like the l/h spacer is 5-6mm to big.
If it was that much shorter the adjusters should go in and the hub will go left 3mm, which it looks like it should.
The right side spacer should be 45mm and the left looks like it is too long but, that maybe down to you don't have a chain guard on. If it is the correct size maybe the swinging arm is a tad out Gary ;)
Ill take it out in morning.
Pub tonight Im officially a pensioner today.
Try it without the shocks on as that maybe pulling it in a tad ;)
Post a pic of the brake plate as well as the 550 is different
I did notice yesterday when i meet you ;D ;D ;D
How rude. :P
How rude. :P
Enjoy your evening out mate.
Happy Birthday Gary, you're wearing very well for a pensioner 😂😂😂
Thanks both, cant wait for the government to start sending "free" money. :) :) :)
Don't encourage him ;D
Bye the way, the spindle nut should be on the LH,near side
Although I don't know if it makes a difference
Happy birthday
It's great being mature (posh word for old)
And having money given to you,
The secret now,is to live a long life
And they pay every 4 weeks
Happy birthday Gary, remember when these where new? ;D
Not sure if it helps but I had issues with the wrong spacers on my 500 K0 frame - the wheel was to the right of centre I have now fitted as below standard ones in SS from Max.
My brake side spacer is 45 mm - chain side is 32 mm I believe if you have 500 hubs they are the standard size.
The distance on the swinging arm at the ends should be 242 ;)
[attachimg=1]
Not that it needs confirming - fwiw my rear forks are 242 between the ends also.
Thanks for all the info (and birthday wishes0
Swing arm is 242
Left spacer is 32
Right is 50 so that must be the problem. I do have others but not a 45.
Anybody got a manky old one they want to sell ? I know stainless are available but I was going to paint it so seems a bit over kill.[attachimg=1]
I think I might have one Gary but away until Friday ‘Oop Norf’.
I’ve got a load in the drawers at home in the shed.
I don't have any the right size as mine were incorrect when I bought the bike.
Well thanks guys, but I just found one. Ted I also found that one you kindly offered. I really must get more organised Ive got stuff all over the place.
It sounds nerdy but I made an Excel Spreadsheet with the location & contents of all my parts - I even turn the item description into pale grey print when I have fitted the part or it's on my bike ramp - took me a couple of hours over a couple of days to do the list.
I still sometimes mislay an item as I was initially lazy with sub-box contents - I'm retired so have plenty of admin time on my hands.
I print a copy off every few weeks that I use in the garage then update when I have made lots of progress or moved stuff into parts grouped boxes etc. It has saved me hours most weeks as I can usually go straight to the right shelf & box.
Yeah, but you’ve taken all the fun out of it Ted!
Just think of the ‘muttering’ you’re missing out on,what a waste
QUOTE: 'I have parts all over the place'............some of you are just lightweights ! LOL.
Kin’el!
Swing arm is 242
Left spacer is 32
Anybody got a manky old one they want to sell ? I know stainless are available but I was going to paint it so seems a bit over kill. (Attachment Link)
Put the 50mm in a lathe and take 5mm off ;)
Swing arm is 242
Left spacer is 32
I cant be trusted with a spanner, so a lathe is a real no no. :)
Swing arm is 242
Left spacer is 32
You know what the problem is now, carry on with the wheel building ;)
Nice to see you have a label on some of the frames!
[/quote]
Ive been waiting 2 weeks for a rim from DS. Should be here Tuesday.
Despite my Spreadsheets I can still look for parts that never existed like my brake pedal return spring. Checking on strip down photos is my last resort whereas if it's not listed it should be my first. My brain is quite good at thinking I have seen something that never was.
[/quote]
I have a right spacer here if you need one, very rusty though ;)
[/quote]
Thanks mate, but I found one in a box of "scrap". Good job I never throw anything away. :)
