SOHC.co.uk Forums => CB500/550 => Topic started by: MIKE550/4 on November 02, 2013, 09:35:26 AM
read the Clymer manual and don't get this
the chain adjusters have punch marks, how defined are these? can you put these on upside down ?
swingarm has been powdercoated?
is this purely for chain tension?
confused by this any help appreciated
There are marks like grooves on the flat part at the back of the swing arm, then you will find a notch on the edge of the chrome adjuster so that you can see how far you move each side.
Can;t remember if the adjusters have a notch on top and bottom or only one side---if only one side then yes they can be upside down.
POINT TO NOTE:- all the books say to get the wheels lined up with a straight edge and not to trust setting the notches at the same mark each side, but having said that I have yet to find one that does not match
They are generally for wheel alignment but I am yet to come across a bike, new or old, where these seem to mean anything in relation to wheel alignment.
Can you shed some more light. Mine (CB500) seem to be allright.
I have just found that on the bike I have had they are not very accurate, thus leading to wheels that are not aligned properly. Modern Suzukis being about the worst, not sure how they manage it really.
It became clear when I used to let go of the bars now and then and the bike would steer one way or the other, when I measured it with string then it showed the wheel was out, pretty annoying, as a result I have never used them I set the bike using string and then adjust using 1/4 turns when needed and now and then double check with string.
Might just be me buying bent bikes but of the c15 bikes I have owned 1 has been okay.
Just my tuppence
Sharpy
got a better understanding now, I can see marks top and bottom on chain adjusters after having a better look, so don't think it matters which way
ok another query, I can see marks faintly on the swingarm perhaps 6 lines vertical
I take it you align marks with chain adjuster and swingarm furthest into the swingarm and then fit chain and pull back wheel to take up slack for length of chain?
will put some pics up tomorrow to confirm
thanks for input learning all the time
These are what are being discussed in the above posts.
Put your wheel on, put the chain on and adust the slack. The marks on the swinging arm are to ensure the rear wheel is aligned.
I never trust those marks either and use the string to check mine.
I see so a guide only for wheel alignment..... just re read all the posts, I was concentrating more on using it for chain adjustment
Mike, they are for chain adjustment. You move the wheel the same number of marks each side AFTER you have the wheel alignment right
