SOHC.co.uk Forums => CB750 => Topic started by: jojotut on June 11, 2014, 11:34:30 AM
Hi everyone, trying to piece together the proper specification for the above bike. I have read quite a bit of information but would like to pick all your brains on the spec this bike left the factory before I start pulling it apart again.
Colour, although the tank is gold I don’t think that this colour came out before frame number ###20000, mine is around the ###19000 mark.
Tank, should it be a wrinkle tank?
Front mudguard, should it be single or double cut?
Seat, should it be ducktail?
Can anyone give me the correct spec for this bike I know they changed them very rapidly over this period.
Every bit of info would help.
JOJO
Hi Jojo, is your bike a uk bike ? cheers Mick ;)
Hi no I bought it a few years back from an importer, I have been buying original nuts and bolts from Germany, got some new forks and wireing harness from the States. Its a US spec bike.
Its complete and runs all chrome is good, but I think the front mudguard is a later one.
Should it have a black kill switch (forgot to ad this one to the list)
Exhausts are repairable but not `300`. I will replace these with pattern ones (Anyone know where the best place I can get some from).
JOJO
Hi Jojo have you had a look on cmsnl website they give you all the different models may be of help for you ;), cheers Mick
Think Gold was available at the end of '69 (there was a pic of one on the US site) and of course one of the 'Brighton Show bikes' was gold/white. Also seen a couple asian market gold ones that GI's brough back after Vietnam. Two colours available originally were Candy Ruby Red and Candy Blue Green. A person on US site from Toronto posted a pic of a sandcast bike he bought in summer '69 Gold/white stripe tank.
Definitely should have ducktail seat.
Almost certain double cut fender at front (mudguard) with no cable grommet thingy.
Hmmm on wrinkle tank . My 10/69 UK K0, I am pretty certain, did not have one originally. But hey-ho everyone seems to disagree.
I think it should have 'antimon' alloy fuel cap too and no black stripe on bottom seam fuel tank trim.,
Black Kill switch for definite & recessed ignition switch.
Narrow front hub / two hole rear hub.
Louvred side panels.
Short style plastic chainguard (may have been swapped as recall though).
Oh and that tw*t of a rolled rear DID
rim that I can't get hold of.
Silvers for exhausts as they are Yamiya (or were) and you save yourself import/shipping duty .. but check as he is having HM341's made in Italy now. Yamiya ones definitely good quality I believe.
Shoot me down if anything is wrong !!
Cheers ...AshD
Colour is down to you as not even Honda can tell you what it left the line with
Ash has covered the list of items you should have quite well, do you have any pictures of the bike you can post on here?
pete
Thanks for this info lads its very helpful.
On the pipes thought these should be MH300, still cant afford them.
Nice info on the wheels will take a look, I will post pictures (hope you wont laugh).
Should carbs be 4 cables into one, mine does.
JOJO
... this any use?
http://honda750expert.com/
Simon
yes 4 cable carbs and HM300 pipes, the early k0 pipes had no numbers, but i am pretty sure by your model they were hm300
pete
Carbs definitely 4 cables into 1, apart from transition 'K0' model in late 1970.
Don't worry about pic, Any K0 is worth restoring. (as long as you have deep pockets ;)). And drives you nuts trying to locate the correct parts.
Cheers .. AshD
Thanks for the url Lobo, great info.
Thanks for everyones help
Pictures are on the way
JOJO
