SOHC.co.uk Forums => CB350/400 => Topic started by: Nurse Julie on January 06, 2015, 09:47:52 PM
Hi Chaps.
What way do your split exhaust collars go in ?. I'm sure that when I took mine out the phlange end was down inside the head but in the Haynes manual they show the phlange out by the frilly retaining rings. I have looked on internet and article on DSS says 'make sure you note which way round the collars are so you can replace them the same way' which leads me to believe they can go either way. I'm confused............please help :'( :'( :'(
Ta in advance
Julie
The flange goes against the frilly thing. It has a recess for it. Would they fit the other way round? The non-flange end bears down on the downpipe flange which in turn presses against the gasket.
Thanks Tom, that all makes sense. I have a feeling that was the way they were before I took the pipes off. I think what has thrown me is the article I read on DSS site which made me think 'what way were mine in' !!!!
Thanks for your help
Regards
Julie
Diag...
Thanks Tom
Keeping the retainer rings from sliding down the pipes is another trick.
I use old socks wrapped around the pipes to hold them !
Or get some narrow masking tape to hold the two split collets together(one turn round) which is what Honda did
Thanks Bryan and Clem, the socks and tape have just worked a treat, pipes all fitting nice and snug. Not the easiest of jobs to do though, all that pushing, pulling and twisting.
Regards
Julie
Regards
Julie
Just like being a dentist ;D
Regards
Julie
Don't mention dentists :( :(. As a Nurse I can't stand anything related to teeth, eyeballs or ingrowing toenails. Have had to keep my eyes shut in the past when working as a Scrub Nurse on any of these parts, not ideal as you can imagine. ;D ;D ;D
I googled scrub nurse :o
Well anyway: https://openclipart.org/detail/168580/enrolled-scrub-nurse-by-bedpanner
Yep, that's how I dress up sometimes, for work, not pleasure I hasten to add ;D ;D ;D
And i thought you were the doris that was always dressed up as a nurse in Pink Punters club on a Friday night ;D ;D ;D
:o :o :o I had to look up Pink Punters, never heard of it. Now I've seen it, take it from me I do not fit into any of those gender categories but I would go there for a night out for a laugh but then I can have a laugh anywhere ;D ;D ;D
Is that where you go Trig?
Tom... loved the tech-speak..."the flange goes against the frilly thing"!
But... worked for me, couldn't have put it better!
Haha. I can't let Tom take the blame for the parts I called 'frilly things' in the first place. At least he knew which bit I was talking about. ;D
I will tailor my discourse to the opposite party, Simon. In your case, with your engineering precision I might say "the finned exhaust clamps incorporate a recess to accommodate the flanged side of the collets, which in turn mate against the downpipe flange and thence the fibrous gasket"
But you really can't quibble with "frilly thing" as a concise and succinct expression of the same thing. Mars and Venus I suppose...
Sorry Julie! Missed that...
Maybe ladies should be more involved in engineering; Tom's corrected version might be more accurate... but hey, it took me 1/2 a day to work out what he was saying!
Then again, I've just been musing my missus's various attempts at describing faults.. ayeee....
