SOHC.co.uk Forums => CB750 => Topic started by: PHILIP2908 on March 13, 2016, 10:50:00 AM
Found the oil leak.....
When I bought it I could see it had been 'down the road' a few times but I wasn't expecting that.
Also, while I'm on: I've had all the plug leads off and didn't mark them. (doh!)
Looking at the points, I assume the leads from one coil serves cylinders 1 & 4, whilst the other serves 2 & 3. But which of the two coils goes to which??
Have a look inside the points cover to see what colour wire is connected to the set of points marked 1&4, then see which coil has that colour attached to it, and there is the answer. If the wiring is stock it'll be blue or yellow.
Sent from my X5 using Tapatalk
1,4 blue, 2,3 yellow. Left points 1,4 Right points 2,3
