Author Topic: CB750 Won`t go above 40-50 MPH  (Read 9356 times)
Offline JonnyHonda
« on: November 18, 2003, 01:24:48 AM »
I`ve had my CB750 for about 3 months, bought it as a running repair.
andyw
RE:CB750 Won`t go above 40-50 MPH
« Reply #1 on: December 03, 2003, 03:03:50 AM »
Sounds like an electrical problem. Check the Plug leads are not damp/loose etc.
On these bikes a fault o
algs750
« Reply #2 on: December 10, 2003, 08:24:31 AM »
Had the same problem o­nce and it turnedout to be blocked jets.
fothers
re:CB750 Won`t go above 40-50 MPH
« Reply #3 on: May 08, 2005, 06:40:45 AM »
Hi,
Had a similar problem with my '77 550F2. The bike would start and idle ok but would not pull much above 40-45 mph. If the innards of the points stator plate are similar (which I think they are) it might be worth looking at the auto-advance mechanism - see of the springs are ok and the mechanism is not sticking. I cleaned mine and the problem went away.
Cheers,
Pete.
 EDIT: Check this out in the AvantGo section of this website: http://www.honda-sohc.co.uk/print.php?sid=19
[Edited on 8/5/2005 by fothers]
