Author Topic: Front wheel spindle K6  (Read 738 times)
Offline kevin 755
« on: May 05, 2016, 03:55:18 PM »
Take the front wheel off how do you remove the spindle and speedo gearbox?
Thanks Kev.
Re: Front wheel spindle K6
« Reply #1 on: May 05, 2016, 04:06:43 PM »
There is a cross hole in the spindle one end, and a the nut is a sleeve nut at the opposite end. put a tommy bar or similar through the hole, and unscrew the sleeve nut with a deep socket or good fitting ring spanner.
Offline kevin 755
« Reply #2 on: May 06, 2016, 04:00:47 PM »
Cheers Hairygit,worked a treat.
