Author Topic: (CB750 and others) Master brake cylinder overhaul  (Read 1312 times)
Offline Sgt.Pinback
« on: May 07, 2016, 07:06:48 PM »
Will have to overhaul my KO master brake cylinder. Boot is toast.
In order to get out the clip of the master brake piston HONDA says grip 07073-30001.
Where to get one or what tool do you use?
cheers, Uli
Offline Liam
Re: (CB750 and others) Master brake cylinder overhaul
« Reply #1 on: May 07, 2016, 08:42:04 PM »
Something like this I thinkā€¦
https://www.koolairconsupplies.com/trident-t244100-snap-ring-pliers.html
Or try an ebay search for long nosed circlip pliers...
Offline Green1
« Reply #2 on: May 07, 2016, 09:18:13 PM »
I found I had to grind down the pliers in your link to reach the clip
I have since found it easier to remove the clip with a small pick or screwdriver
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Chris400F
« Reply #4 on: May 08, 2016, 11:05:09 AM »
If the seals are OK and its just the boot you only need to get out a wire coirclip that is not in a groove
