Can anyone tell me which wires go where wiring in an electrex RR24 reg/rec unit into a '77 550F2? I thought I had it right, but not charging.
I've currently got white green and 3 yellows from the generator running to the same colours on the reg/rec, and the red from the reg/rec going to battery positive and the black from reg/rec to switched power.
Should the green also be grounded back to battery negative?
Help!
Sent from my SM-N9005 using Tapatalk
