Author Topic: Pattern clutch cable - opinions?  (Read 973 times)
Offline Rozabikes Tim
« on: May 08, 2016, 08:40:14 PM »
Looking to get my 400 up and running to see if there are any problems before I start restoration.
 No clutch cable at present, so looking to get one. Are original parts still available and what are the best pattern brands? What issues should I be concerned about etc.
Advice appreciated.
Tim
Re: Pattern clutch cable - opinions?
« Reply #1 on: May 08, 2016, 08:59:02 PM »
Yes, genuine ones are still available, not particularly cheap, but they fit perfectly, perform better than any pattern one on the market. D.S.S. also do one from the original equipment manufacturer, obviously exactly the same part they supply Honda with, but not in a Honda bag, so is cheaper!
Sent from my D2303 using Tapatalk
Offline Chris400F
« Reply #2 on: May 08, 2016, 09:16:26 PM »
I hear what is said about using genuine parts but I fitted one of these:
http://www.ebay.co.uk/itm/New-Honda-CB-400-4-F2-Four-1979-400-CC-Hi-Quality-Clutch-Cable-/131741461628?hash=item1eac672c7c:g:ZYsAAOSwDN1UNq5Q
No problems with fit and cable seems fine to me.
Offline Chris400F
« Reply #3 on: May 08, 2016, 10:08:51 PM »
Another thought - as you have no cable at present you may not know the routing.
Check out the CB400F Dealer Setup Instructions in Ashimoto's Dropbox if you need the details.
« Reply #4 on: May 08, 2016, 10:40:04 PM »
Cheers Chris top advice.
