Author Topic: rear brake drum repair  (Read 1177 times)
Offline 3scs
« on: May 13, 2016, 07:12:56 PM »
hi just wondering has anyone done the rear brake drum repair would you recomend using any loctite if so which one would be best to use
Re: rear brake drum repair
« Reply #1 on: May 13, 2016, 07:15:21 PM »
Which rear drum are you talking about?
Offline 3scs
« Reply #2 on: May 13, 2016, 07:18:35 PM »
sorry its cb 550 k3
« Reply #3 on: May 13, 2016, 07:21:32 PM »
Need to be shrunk in not loctighted
Offline 3scs
« Reply #4 on: May 13, 2016, 07:29:19 PM »
wasnt sure wether to loctite also thanks
Offline matthewmosse
« Reply #5 on: May 13, 2016, 08:25:34 PM »
When I did mine I froze the insert, and heated the hub using acetalene whilst it was spinning on the lathe, then used the tailstock to push the two together, on a spare wheel I have that was re lined by someone else they also drilled 3 points along the joint and tapped then inserted grub screws so they were half the diameter into hub and half into liner. I would immagine that required a very stable drilling platform for the drill to go square and not veer off into the soft alloy. Personally I was happy to use the tight fit and heat expansion by themselfs and save a tricky bit of work.
