Author Topic: Starter motor wire size  (Read 1371 times)
Offline yozzer74
« on: May 14, 2016, 08:20:01 PM »
Hi I'm wanting to extend my starter motor cable does anyone no what gauge size I will need cheers yozzer
Offline archmill
Re: Starter motor wire size
« Reply #1 on: May 15, 2016, 11:31:23 AM »
I used 16mm2, 110 AMP. De-soldered the existing cable from the starter motor, filed the internal connection flat with a needle file and replaced it with a button head screw from inside ( 6mm I think ) with a washer and nut on the outside with enough thread to take an eyelet and nut and put an eyelet on the new cable with a rubber boot, therefore no joints from starter solenoid to motor.
Archmill
« Reply #2 on: May 15, 2016, 11:58:51 AM »
What he said...
Replace the entire length, don't extend it.  With high currents, joints = overheating = unreliability.
Offline yozzer74
« Reply #3 on: May 15, 2016, 07:07:51 PM »
Thanks for advice I will give it a try
Offline yozzer74
« Reply #4 on: May 15, 2016, 07:27:25 PM »
Can you get starter out with out taking the carbs off
« Reply #5 on: May 15, 2016, 09:20:47 PM »
Yup
Offline yozzer74
« Reply #6 on: May 27, 2016, 07:35:50 AM »
So I've got the starter motor out got the old cable off do I still need to use the nylon spacer that the old wire passed through.so the cables doesn't touch the starter housing .
« Reply #7 on: May 27, 2016, 10:08:33 PM »
I would
Offline archmill
« Reply #8 on: May 28, 2016, 11:27:13 AM »
yozzer74, you have to insulate the cable from the starter motor housing, remember it will be live when you press the starter button and the starter housing is earthed to the engine. Once the new cable is fitted you must check it with a meter to make sure the starter cable touches nothing but the connector inside the started motor. If not, big sparks, quite spectacular LOL
